V-4 FORD engines
Discussion in 'The Hokey Ass Message Board' started by RATCAMINO, Oct 10, 2008.
  1. RATCAMINO
    RATCAMINO
    I gotta chance to purchase an old v-4 ford engine just lookin for some info, parts availability, cubic inches , approximate value , etc.
    Any help would be much appreciated.
  2. Bruce Lancaster
    Bruce Lancaster
    Early '60's Taunus?? I think sold here as industrial engine?
  3. unkamort
    unkamort
    Same mill that was in the early Saabs? They were fairly successful in European rally racing back in the day. Might be a good point to start your research.
  4. altraditional
    altraditional
    from Estland
    It was quite common in european fords during 60s and 70s. But they weren't having too much displacement or power.
  5. Pete Peterson
    Pete Peterson
    I have owned a couple of Sasb Sonetts. The V-4 was made in Germany and installed in Saab Cars. I think 2 sizes 1900cc and 2100cc. Ran alright nothing available to hop up except rally eqp. Just a pushrod engine. check with (Jack Ashcraft in Medford, Oregon) if you are serious. I sold my 68 and it went back to the (old country) Pete
  6. Used in British Fords too, with 1700 and 2000cc versions. Can´t recall hearing anything good about these motors.
  7. LIMEY
    LIMEY
    The Brit V4 was a smaller version of the Essex V6...... not very reliable mechanically but was good for torque not rpm, always had cooling & head gasket issues.
    However the German Cologne V4 also a smaller version of a V6 was was more refined, revved much easier & would last good into high mileage.
    I worked on both when they were poular here.
    Kev.
  8. Chevydeuce
    Chevydeuce
    The german V4 had in the biggest version i think 1700ccm?!!
    About 75hp or so.
    They had probs with the cam gears and the valveseats.
    Other than that I don´t know much about those.
  9. Paul Y
    Paul Y
    No power. Vibration. Unreliable.
    The only thing going for it is it is compact.
    If you want a 4cylinder ford get a Pinto or a Cosworth motor.
    I hated working on the V4's when I was a mechanic.
    P.
  10. Barn-core
    Barn-core
    Something like this?
    I saw this at G.G. Pleasanton earlier this year. The guy said it was an industrial motor. He also said it fit a Chevy pattern bell housing. I thought it was pretty cool.
  11. RHOPPER
    RHOPPER
    Early Saab, and some brands of bobcat/skidsteer used the industrial version of that motor.
  12. 97
    97
    If ya haven't got a boat you probably don't need the anchor!!
    It's a lemon.
    They are not even half a V8...they are two thirds of a gutless Ford Grenada/Essex V6. ....If it is a German Taunus/Cologne version it might be a little better but will be 1700cc ( 103 cubic inches) at most .
    They had reliability issues , even near new, came to NZ in Ford Transit Vans, most got replaced with V6s which wasn't much better . Parts are hard to find now, and I somehow doubt there are any real aftermarket performance parts .....
    Heaps of peoblem areas but it was the Oil pump drive, timing gears, balance , blocks, and cylinder heads mainly gave problems , apart from the overheating and gutless performance and dodgey machining from the factory.
    A good rundown can be found here
    http://www.baconsdozen.co.uk/motorhome/essexengine.htm
  13. metalshapes
    metalshapes
    Yep...
    I had a Ford Transit Van with one.
    Shook the exhaust pipes off the engine.
    ( fortunately the I-beam was under the engine, so the pipes weren't draging while I drove it home )
    Drove a German V6 for a little while too, didn't like it either.
    I wouldn't want either one again, unless it was free.
    ( and that's only because the guy who picks up my Junk Steel is a very good friend of mine...)
    Ford made lots of engines that were better...
  14. metalshapes
    metalshapes
    Saab probably used it because they had an Engine Bay that would fit a 3cyl inline 2-stroke engine.
    When they finally got rid of it, they replaced it with a Triumph Engine.
    ( so I guess the bar wasn't set that high...:D )
  15. "Doc" Parsons
    "Doc" Parsons
    I don't have one but I do have an all aluminum v/4 Chevy
    "Doc" Parsons
  16. solid
    solid
    the owner of the company my dad worked had a saab w/ one in it. neat to look at, but my dad was always doing something to that engine.
  17. draggin breath
    draggin breath
    The early Ranger v-6 was a big brother of this. Had solid lifters and would wind tight.
