Technical Using Web Straps to Suspend Engine from Shop Crane & Leveler
Discussion in 'The Hokey Ass Message Board' started by Paul Bennett, May 13, 2019.
  1. Instead of using chains. I'm told web straps are best for getting an engine in/out of a car. Especially on a painted engine with chrome goodies and aluminum heads, thereby no damage is done to the bright-work.
    So,
    Where does one find-get these heavy duty cloth/web straps? Seat belt outfits? Comments appreciated.
    FYI - flathead engine holding the suspension webbing at corner exhaust manifold bolts into block.
  2. banjeaux bob
    banjeaux bob
    from alaska
    Search google "certified lifting straps".... you'll find enough sources that if look at them all you'll go blind.
    Hnstray likes this.
  3. Dirty Dug
    Dirty Dug
    I bought a flathead one time from a guy who had it suspended with fan belts around it, from a chain hoist, wouldn't recommend it but they worked.
    deathrowdave likes this.
  4. clem
    clem
    Personally, I would only use a reasonable size chain, but as most engines are only 200-300 kgs, I would think that good high rating web strap would suffice.
    Be interesting to see what others use.....
    Flathead Dave likes this.
  5. Thanks BBob. 360 results should do. Most of life we search for the right name or words to use in a search. I think 'certified' is the magic here.
  6. Flathead Dave
    Flathead Dave
    from So. Cal.
    Chain here. If it was good enough for our family baby sitter to use on us when we were kids, it's good enough to lift motors.
    gas & guns and Do it Over like this.
  7. Check with rental places or rigging contractors. Nylon lifting straps are very commonly used for lighter loads (say 5 tons or less, although I've seen them used on larger ones) and have a service life so they're replaced regularly. Most are rated at well over one ton, so even a somewhat worn one will easily handle a 5-600 lb motor. The trick will be finding some that aren't real long.
    Inexpensive tow straps work well too, although they tend to have quite a bit of 'stretch' to them. Upside is most have hooks on each end.
  8. spanners
    spanners
    I use chain with a bolt through into somewhere on the block, front and rear. The thought of a web sling slipping on an oily sump and the engine going arse-up whilst halfway out of the engine bay is something I'd rather avoid.
    Chappy444 and clem like this.
  9. RMONTY
    RMONTY
    I bought a couple purple colored straps that from HF. They were cheap, and I have picked up everything from my 235 engine to a 4 door 52 Chevy body with them. They have held up fine.
  10. F&J
    F&J
    If you had a big plumbing supply place there, you might be able to get some for free. They are a continuous loop and come on bundles of copper water pipe from the manufacturer to be able to be transported & unloaded. Most are 1-1/4" or 1-1/2" wide, They are safety labeled as rated at 3000lbs single loop, 6000 if doubled.
    They don't slip, I've used mine for engines, and all sorts of things. On engines, run it under the front crank and under the back of oil pan in front of trans or flywheel. Then the sides of the strap keep the motor from flopping over to one side.
    Beanscoot likes this.
  11. dreracecar
    dreracecar
    from so-cal
    Auto swap meets usually have 2 or 3 vendors selling the same straps
  12. How many have done the seat belt lift at the junk yard?
    ,, they are strong and free, unless you try to take them with you
  13. nochop
    nochop
    from norcal
    Hard to adjust straps to get the proper angle. In my opinion
  14. DDDenny
    Just like with chains it's all about the rigging, the straps are susceptible to getting small cuts that aren't always visible, all the certified straps will generally have red stranding in them to alert to cuts. I ran a toolroom and bought thousands of dollars a year worth of straps because guys wouldn't protect them from sharp edges. We had to stay one step ahead of OSHA so they got pitched pretty regularly, everybody had straps at home, never had to buy any.
    Just keep an eye on them and put a piece of thick cardboard between them and any areas that may cut them.
    BrokeBastards and belair like this.
  15. I cut up a 100ft climbing rope into various lengths and made slings. Super strong - you could suspend a car from the 12mm stuff and it is made to take hard abrasion.
    Sent from my moto g(6) play using The H.A.M.B. mobile app
  16. captainjunk#2
    captainjunk#2
    dont cheap out on web straps they work well for lifting if you dont exceed their capacity we lift 500 lb steam shut off valves on top of the boiler at the plant with them and a chain fall ,
  17. indyjps
    indyjps
    Ive used them, prefer chains, even if you put some padding in between chains and engine.
    All the lifting straps Ive seen. Dont think the individual actually purchased them, they all seem to be procured from a workplace or jobsite. DDDenny, thats probably why you had to buy so many.
    Straps break down, get torn, get soaked with solvents and oil that weaken them. Chances of several 2 inch wide straps breaking during an engine lift are minimal. I still like chains.
    clem likes this.
  18. olscrounger
    olscrounger
    I use both. the Slings I use are from Utility Line work. They are older but in good condition. I inspect before using-Some are rated at 5K and above. Just looked-some rated at 12,800 lbs Spent 45 yrs in the overhead line trade-used them often doing alot of rigging.
    VANDENPLAS likes this.
  19. DDDenny
    The front office said "you inspect them, you pitch them, you replace them", I had no problem with that and they were happy to not pay OSHA fines.
    The dumpster divers had a field day.
    indyjps, VANDENPLAS and olscrounger like this.
  20. Straps go places where chains can't. Chains with a spreader bar will clear all your shiny bits.
    Common sense can be used with both.
    TrailerTrashToo likes this.
  21. noboD
    noboD
    MSC has them, so does McMaster-Carr, MUCH better then chains.
    gimpyshotrods likes this.
  22. 283john
    283john
    I've used a yellow tow strap wrapped about three times around the engine and hung on the hoist...but it was an inline 6 amd pretty easy to balance right-side-up.
  23. ramblin dan
    ramblin dan
    Chains all the way. If I'm worried about a newly painted engine I cut and slip a bike tire tube over it.
    nochop likes this.
  24. s55mercury66
    s55mercury66
    from SW Wyoming
    The slightest cut one would would get us an OSHA citation, so our front office eventually decreed they be inspected weekly, and replaced monthly, ready or not. Most roughnecks have enough of them to pull a loaded coal car from a hundred feet away. Wilson Supply, NOW, McMaster Carr, any crane rigging supplier, there are tons of suppliers, Google will find one near you. Personally, I like my chains. I bolt them on, and remove stuff that will get damaged by them, valve covers being a favorite target of them. Way easier than running a sling under an engine in the car.
  25. noboD
    noboD
    A cut exposes a red thread meaning they are junk. If it's red it's dead.
  26. indyjps
    indyjps
    Is that on crane straps only? Ive seen a lot of flat yellow tow straps used a engine pullers, as 283John described. Ive done it. Prefer not to.
  27. DDDenny
    As far as I know the "certified" straps have some form of an indicator of a cut, may not always be red, not positive.
    Those generic "tow" straps will more than likely not be certified.
    indyjps likes this.
  28. alanp561
    alanp561
    Westech Rigging Supply in either Eugene or Salem would be a good place for you to start. I've bought 1 1/2 " Nylon chokers from a local cable and sling vendor that are good for 1500#. Shouldn't cost you over $25 for a 6 footer. If you take care of them, use softeners on sharp edges, and never, never, never tie knots in them or slip one choker through the eye of the other one, they'll last a long time. Buy a couple of 1 1/2 ton shackles so you can rig it right.
  29. 1946caddy
    1946caddy
    from washington
    Took pictures off of a new one.
    deathrowdave, VANDENPLAS and alanp561 like this.
  30. noboD
    noboD
    Millwright for 20 years. All of ours showed red when cut, but I don't know everything. I doubt is Horrible Freight's show anything when cut.
