There's been a few posts in the past questioning what their welding machine can do. Well.....Perform a Fillet Fracture destructive testing method on the exact same material as your weldment. To keep it short. Here I'm using normal frame material, 1-1/2 x 3. Stand the tube on the other tube and weld a fillet weld on 1 side of the tubing only. Let that cool. Stand on the tube with one foot & push the tube over the fillet weld with your other foot. Passing weld - the steel will tear. Failing weld - Looks good, but doesn't tear. This is why you dial your machine with scrap before welding the weldment. View the pics in order and both of these are performed with my Miller 110 machine.....'cause if I did it with the 220; you know you'd all come back and say "Do it with the 110" Carl Hagan
thank you!!! its about time someone explained, in simple terms, that a 110 welder can do more then most think. Now maybe all the "experts" will think twice before automatically saying "do that with a 220V"
I guess I could've elaborated more on the pics. Left one is passing & the right one looks like the nice weld with the blue heat ring, but low and behold.....The tubing merely bent, unlike the passing one where the tubing wall clearly tore away. Cool and thanks for the prop's guys, Carl Hagan
No, a 110 welder in CAPABLE HANDS can weld well. Most that ask the question here do not have the experience to pull it off consistantly.
Thank you for the info. Just got a new welder today. Sold the last one about a year ago and missed it ever since.
Thanks for the tech, I didn't know how to do this, it'll definitely add to my confidence with welding!
Thanks Carl! Folks can show off pics of pretty welds all day long, and it's really not helping anyone learn anything. An example like this helps clear up a lot of the welding questions on here.
Friggining EXCELLENT! nice visual depiction. if you can SEE the difference in the two beads, you're MILES ahead!
PERFECT! Thanks for the pictures and write up! That is a very easy way to "double check" your welding process. Much easier then what I was trying to figure out what to do!
