Technical Upholstery question
Discussion in 'The Hokey Ass Message Board' started by 41 C28, Aug 25, 2016.
  1. 41 C28
    41 C28
    A (dumb) upholstery question. What is the proper name of the cardboard material used for interior panels? Thanks
  2. 28TUDOR
    28TUDOR
    Chip board I think?
  3. Guy used PVC panels instead of cardboard on my car. Said it wouldnt warp like the cardboard.
    Sent from my SAMSUNG-SM-N900A using The H.A.M.B. mobile app
  4. 51 mercules
    51 mercules
  5. cb186
    cb186
  6. Rusty O'Toole
    Rusty O'Toole
    The black cardboardy stuff in large sheets is car panelboard. The thin stuff in small sheets is furniture panelboard. You want the black waterproof .10" thick kind for car door panels. Don't forget to put plastic between the door and door panel or the damp will warp it.
  7. I've used both. By far the best is the poly Sheets. They never warp.
  8. 58custom
    58custom
    Who sells poly sheets?
  9. Atwater Mike
    Atwater Mike
    Sid Chavers uses Luan plywood, illustrated on his tapes.
    My mother in law, Joyce watched the door panel tape, (she's an A-1 upholsterer and seamstress) Joyce said she learned 3 new methods right off the bat!
    I was impressed with Sid's method of clear plastic for a pattern. Set it up, look right through it for the attaching holes, mark with a Sharpie...
    The Luan ply works excellent, it holds its 'flatness', but if necessary can be wetted and shaped with water and a heat gun. Permanent. Glue to it, staple to it.
    lothiandon1940 likes this.
  10. Any upholstery shop worth its weight in salt will sell the poly sheets.
  11. brady1929
    brady1929
    from Mesa, Az
    Great info here, thanks.
  12. spooler41
    spooler41
    The trade name on the Polly sheeting
    is " Centra", 1/8" works well for interior
    backing. It's also waterproof and heat
    formable.
    .......... Jack
  13. plywude
    plywude
    from manteca ca
    X 2 on the water proof board all upholstery supply houses will have itpplt
  14. BigDrag
    BigDrag
    from Milwaukee
  15. I uses 1/8 " ABS plastic panel board, it can be sanded, drilled, cut with a sharp knife and bent with a heat gun and is not affected by moisture.
    I think it was the perfect answer for upholstery backing.
  16. OLDSMAN
    OLDSMAN
    I used PCV Sheets for the door panels in my convertible. I love it never warp, water won't affect it.
