Projects update on the Model A Coupe
Discussion in 'The Hokey Ass Message Board' started by Paul, Sep 5, 2010.
  1. Paul
    Paul
    Editor
    ok, I'll do that
    but here it is, not all bolted down though, just one more dry fit.
    now I can see exactly what all the misc nuts and bolts need to be like,
    and I need to get another pilot bushing made before I can bolt the transmission up.
    had to pull the old bushing, the Muncie input shaft didn't quite reach far enough.
    but it's on the test stand, should be firing it up soon I hope..
  2. kisam
    kisam
    THUMP THUMP, THUMP THUMP! That gold is the perfect 60's color! Hope you get a video and good luck with the start up! How much boost are you running with 8 1/2 compression?
  3. DirtyThirty
    DirtyThirty
    from nowhere...
    That thing looks great.
    The motor, the car, all of it...I like the gold, too, it was popular then, and it should have been. It looks great against all the "silvery" metals...great compliment to them.
    What front axle are you using?
    It looks like less than 4" of drop, but looks perfect, with the channel.
  4. REM/Mo
    REM/Mo
    from Missouri
    Nice looking engine.
    What are you using to make up a pilot bushing.
    Does brass work or must it be some type of special material?
  5. Paul
    Paul
    Editor
    M21 Muncie 4 speed for now..
    and a '57 Olds rear with '60 posi pumpkin, 3.90 gears, Dutchman axles..
  6. Paul
    Paul
    Editor
    thanks Kathy,
    don't remember exact boost numbers off the top of my head..
    I'll have to find my notes..
    it's slightly underdriven though...
  7. johnny bondo
    johnny bondo
    from illinois
    triple belt woulda been cooler.
  8. Paul
    Paul
    Editor
    thanks, it's an axle I picked up a one of the local swap meets, dropped and drilled localy... I think it's a '35-'36 with about four inches total drop
    bronze, specific alloy for this type of bearing
  9. Paul
    Paul
    Editor
    I can't seem to find my notes anywhere...
    but if memory serves (and it rarely does),
    the target boost was to be about six pounds...
  10. Paul
    Paul
    Editor
    rebuilt the carbs and got a new pilot bearing on the way..
  11. I'm going to run the same Pont Olds rearend in one of my A coupes,do you have any photos of how you have it hung,or the width??
    Thanks
  12. oh, gawd yes!
  13. fab32
    fab32
    Coming along nicely and it's going to be killer when its all buttoned up and you do that first smokey burnout. Of course we'll DEMAND a motion picture kinda thing when that happens.:cool::)
    Frank
  14. moses
    moses
    that gold color is bad ass.....jeffrery ..perfect
  15. FRITZ
    FRITZ
    Paul;
    That is "Fan-freaking-tastic"
    how does one-shot hold up on an engine?
    FRITZ
  16. VA HAMB
    VA HAMB
    MAN!! I want a blower!
  17. Paul
    Paul
    Editor
    this is the first time I've used it on an engine,
    everything I've read sounds good though.
    I guess we'll see.
  18. 57tony31
    57tony31
    from Woods
    StaticThis may help you
    Compression Blower Boost pressure (psi)
    Ratio 2 4 6 8 10 12 14 16 18 20 22 24 26​
    6.0:1 6.8:1 7.6:1 8.4:1 9.3:1 10.1:1 10.9:1 11.7:1 12.5:1 13.3:1 14.2:1 15.0:1 15.8:1 16.6:1
    6.5:1 7.4:1 8.3:1 9.2:1 10.0:1 10.9:1 11.8:1 12.7:1 13.6:1 14.5:1 15.3:1 16.2:1 17.1:1 18.0:1
    7.0:1 8.0:1 8.9:1 9.9:1 10.8:1 11.8:1 12.7:1 13.7:1 14.6:1 15.6:1 16.5:1 17.5:1 18.4:1 19.4:1
    7.5:1 8.5:1 9.5:1 10.6:1 11.6:1 12.6:1 13.6:1 14.6:1 15.7:1 16.7:1 17.7:1 18.7:1 19.7:1 20.8:1
    8.0:1 9.1:1 10.2:1 11.3:1 12.4:1 13.4:1 14.5:1 15.6:1 16.7:1 17.8:1 18.9:1 20.0:1 21.1:1 22.1:1
    8.5:1 9.7:1 10.8:1 12.0:1 13.1:1 14.3:1 15.4:1 16.6:1 17.8:1 18.9:1 20.1:1 21.2:1 22.4:1 23.5:1
    9.0:1 10.2:1 11.4:1 12.7:1 13.9:1 15.1:1 16.3:1 17.6:1 18.8:1 20.0:1 21.2:1 22.5:1 23.7:1 24.9:1
    9.5:1 10.8:1 12.1:1 13.4:1 14.7:1 16.0:1 17.3:1 18.5:1 19.8:1 21.1:1 22.4:1 23.7:1 25.0:1 26.3:1
    10.0:1 11.4:1 12.7:1 14.1:1 15.4:1 16.8:1 18.2:1 19.5:1 20.9:1 22.2:1 23.6:1 25.0:1 26.3:1 27.7:1
    10.5:1 11.9:1 13.4:1 14.8:1 16.2:1 17.6:1 19.1:1 20.5:1 21.9:1 23.4:1 24.8:1 26.2:1 27.6:1 29.1:1
    11.0:1 12.5:1 14.0:1 15.5:1 17.0:1 18.5:1 20.0:1 21.5:1 23.0:1 24.5:1 26.0:1 27.5:1 29.0:1 30.5:1​
    The above chart shows the effective compression ratio of your engine, which combines the static compression ratio with the amount of supercharger boost. Note​
    that for most street applications with 92 octane pump gas, you should keep your effective compression ratio below about 12.0:1
    Static
  19. Paul
    Paul
    Editor
    yesterday was baby steps,
    got the pilot bearing from my machinist freind,
    and bolted the transmission on for a test fit, looks good.
    bolted the carbs to the adapter,
    bent up some fuel line,
    and drilled and tapped a piece of 3/8" stainless rod to tie them together
  20. Shaggy
    Shaggy
    from Sultan, WA
    Lookin good!
  21. JeffreyJames
    JeffreyJames
    from SUGAR CITY
  22. Paul
    Paul
    Editor
    first start after initial run in
  23. killbilly
    killbilly
    Paul.Man that is sweet!! Ihad a friend in high school with a J-2 in a 31 roadster
  24. Boones
    Boones
    from Kent, Wa
    Paul I have used One shot on a motor and it held up just fine.
    motor looks great. can i have a ride...
  25. Looks good Paul. you gonna have that car done by the poker run this year?
  26. chaddilac
    chaddilac
    Paul... How'd the 1shot hold up after the run in???
  27. Paul
    Paul
    Editor
    thanks,
    maybe next year.. or the year after that, or at the rate this car is coming together who knows :rolleyes:
  28. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    what poker run?
    I wanna go!
  29. Paul
    Paul
    Editor
    a little scorched around the exhaust ports as expected
