Unusual engine photos
Discussion in 'The Antiquated' started by William Thompson, Sep 28, 2018.
  1. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Thank you T-Head.
    One can argue that the Duesenberg race engine was the original "crate motor" offered for sale to the public. I have heard that they sold for around $700. Of course, this at a time when you could but a new Model T Ford for about $250.
    I may paint "Powered by Duesenberg" on the hood of my replica champ car.
    Deuces, motoklas and Jet96 like this.
    twin packards
    I think
    Thor1, brando1956, Jet96 and 7 others like this.
  3. j hansen
    j hansen
    Jet96, Okie Pete, egads and 5 others like this.
  4. AmishMike
    AmishMike
    Just noticed driver sat behind those 2 screaming engines. With 3600 hp screaming in his face at 105 across water took giant stones. Wow, tks for posting
    anthony myrick, Deuces and Okie Pete like this.
  5. saltflats
    saltflats
    from Missouri
  6. stude54ht
    stude54ht
    from Spokane WA
  7. 64 DODGE 440
    64 DODGE 440
    from so cal
    Deuces, Cutlas Fan and motoklas like this.
  8. Cutlas Fan
    Cutlas Fan
    Sure looks like a 2 stroke v8 alright. More info please.
    Deuces likes this.
  9. j hansen
    j hansen
    Jet96, motoklas, Deuces and 1 other person like this.
  10. AmishMike
    AmishMike
    The way 2 cycles breath via crank case I would guess 2 4 cyl with geared cranks. Sort of a V8
  11. moparboy440
    moparboy440
    from Finland
  12. Deuces
    Deuces
    Idles like a top fueler but revs like a Kowasaki (sp) eliminator...:confused:
  13. Cutlas Fan
    Cutlas Fan
    V4 and v6 2 cycle outboard use a single crank so 2 cylinders must share the same crankcase.
  14. motoklas
    motoklas
    from Bern, CH
    Hello,
    It looks to me like two complete blocks of four-cylinder two-strokes, each with its own crankshaft and then geared to one output?
    Ciao, Zoran
  15. Ned Ludd
    Ned Ludd
    It looks like the layout used on the Matra-Simca Bagheera U8 prototype:
  16. AmishMike
    AmishMike
    My understanding one/each crank throw of the v has 2 rods but a sealed disc divider between the rods to allow each piston to compress the volume of air under it separate from the partner cylinder to complete 2 cycle operation. Hope that makes sense & is it correct?
  17. Cutlas Fan
    Cutlas Fan
    What type of heads see on that engine. Sure doesn't look like Buick.
  18. j hansen
    j hansen
    Maybe because it is a Ford 427 SOHC!:D
    warhorseracing, egads and Deuces like this.
  19. j hansen
    j hansen
  20. j hansen
    j hansen
  21. Deuces
    Deuces
    I like them stacked....
  22. Chrysler pavilion under construction -- New York World's Fair, 1964
    Jet96, dana barlow, motoklas and 9 others like this.
  23. Adriatic Machine
    Adriatic Machine
    I spotted this on Face ass 77859470-66DF-4521-B902-028960697D8F.jpeg 9CB9EE1B-0014-4DB3-BC4C-661D4A58222F.jpeg 2A2BB0C7-3580-4CFA-960E-0BF185D78E2B.jpeg E466A4F1-D7DD-4AFA-BEE8-3B2A86E3CCB0.jpeg
  24. Cutlas Fan
    Cutlas Fan
    Then I guess it's not Buick powered as it says!
    Deuces likes this.
  25. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Just to be clear, the original factory designed SOHC 427 Cammer had a chain drive valvetrain. It proved to be somewhat problematical, leading some racers to adapt their own gear drive valvetrains, making the one pictured above even rarer.
    Thor1, j hansen, egads and 1 other person like this.
  26. j hansen
    j hansen
  27. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Which leads to anther puzzle.
    The gear drive will have the two cams counter-rotating - i.e., in opposite directions. The factory chain has both cams rotating in the same direction.
    What gives?
    Did they drive the cam from the opposite end? Regrind one cam bakwards??
    Some hot rodders really go to extremes. Hats off to ya.
  28. Jack E/NJ
    Jack E/NJ
    from NJ
    The smallish extra gear on the right makes them rotate in the same direction. Maybe not???
    Deuces and motoklas like this.
