Technical Unsticking stuck sun visors?
Discussion in 'The Hokey Ass Message Board' started by bigdog, Oct 14, 2021.
  1. bigdog
    bigdog
    Got a couple cars with interior sun visors that are stuck and can't be rotated down. Anybody find a way to get these loose? I'm sure brute force will just break something, and any kind of penetrant or lube will soak through and stain them.
  2. Doublepumper
    Doublepumper
    from WA-OR, USA
    I've freed them up by removing them from the vehicle and working the pivot rod out, cleaning things up and slathering a small amount of grease on the shaft and reassembling.
    lothiandon1940 and jimmy six like this.
  3. vtx1800
    vtx1800
    If they are like most sun visors there are three screws, assuming you haven't taken them out already, once out they are a lot easier to "mess with". The 64 Fairlane sitting in the garage had some ham fisted rider (either my wife's grandpa or grandma) break part of it. I've JB welded the pieces and it seems ok.
    Good luck and use surgeons hands:)
  4. If you loosen the screw it might need a screw driver to open the slot a bit.
  5. hotrodjack33
    hotrodjack33
    If you only drive North and South, you won't need them;)
  6. Crocodile
    Crocodile
    South at high noon may suck
    hotrodjack33 likes this.
  7. bigdog
    bigdog
    Guess I could just drive at night.
  8. hotrodjack33
    hotrodjack33
    Sorry @bigdog , I couldn't resist.;):D
    lothiandon1940 likes this.
