Avoid those awkward brake and clutch pedal positions, making your car safer to drive by giving you clearance between the gas pedal and steering shaft. Flat mount adjusts 2″ horizontally at all degrees and Angle mount goes double. Rubber bonded to steel with a stainless trim ring. https://grumpsgarage.com/product/die-cast-chrome-plated-brakeclutch-pedal/ https://grumpsgarage.com/product/1932-style-pedal-pad-degree-adjust/
