Projects United Pacific 5W Deuce Build
Discussion in 'The Hokey Ass Message Board' started by Groovy, Feb 18, 2017.
  1. It will "work", but it won't "giddy-up" like a hot rod should. And your OD will be practically useless below 95 on the highway. You want your cruising RPM to be at the low end of when the motor is making power so you can accelerate within the power band if necessary. Again, plug your numbers into the formula I posted earlier. I currently run the same .63 OD that you have, and I run either a 30.5 inch tall 700-16 or a 29.5 inch tall cheater slick with a 4.11 rear gear. I started out with a 3.50 gear but swapped it out for some much needed grunt.
    MPH x Rear Gear Ratio x 336 / Tire Height x Overdrive = Cruise RPM
    65 x 3.50 x 336 / 30.5 x .63 = 1,578 RPM
    65 x 4.11 x 336 / 30.5 x .63 = 1,854 RPM
    65 x 3.50 x 336 / 29.5 x .63 = 1,632 RPM
    65 x 4.11 x 336 / 29.5 x .63 = 1,916 RPM
    For comparison, here's your combo assuming a 750-16 (31 inch tall) rear tire:
    65 x 3.23 x 336 / 31 x .63 = 1,433 RPM
    95 x 3.23 x 336 / 31 x .63 = 2,095 RPM
    65 x 3.23 x 336 / 31 x 1.00 (no OD) = 2,275 RPM
    Stogy, loudbang and tb33anda3rd like this.
  2. Groovy
    Groovy
    I knew when I chose the gearing that it wouldn't have the punch. I admit I drive rather civilized and don't like driving hard. Don't even like spinning the tires.
  3. 32fenderless
    32fenderless
    Did the trans shop ask you what size your rear tires were when they said the combination would work?
  4. Groovy
    Groovy
    Yes I gave him a size of 29 inch.
  5. Groovy
    Groovy
    Side exhaust is slowly getting finished... IMG_1854.JPG IMG_1851.JPG IMG_1855.JPG IMG_1852.JPG IMG_1857.JPG IMG_1859.JPG IMG_1861.JPG IMG_1863.JPG IMG_1862.JPG
    brEad, Aaron D. and loudbang like this.
  6. Groovy
    Groovy
  7. Glad to hear about your experiences, it seems the pursuit of a low RMP in 5th gear is often to the detriment of the driveability and performance of the engine. I hope the OP can find a suitable solution.
    Sent from my SM-A520F using The H.A.M.B. mobile app
  8. Groovy
    Groovy
    IMG_2162.JPG Front axle seam has been smoothed out... IMG_2160.JPG IMG_2161.JPG
    loudbang and DeLuxe 32 like this.
  9. Groovy
    Groovy
    Today used the die grinder to give the blended area some texture to make the surface look like a cast finish... IMG_2168.JPG IMG_2169.JPG IMG_2163.JPG
    Stogy, brEad and loudbang like this.
  10. My 32 has a tremec 3550. 3.50 gears and 29" tires. I run 68 mph most of the time at 1750 rpm. Under regular driving, I never have a problem. If I have to really pass someone, I'll put it in 4th. This is a 302 Ford and the truck weights 3300 lbs.
  11. Groovy
    Groovy
    Headers are all together. Next is to TIG all the seams... IMG_2181.JPG IMG_2182.JPG IMG_2183.JPG
    brEad, Stogy and loudbang like this.
  12. Groovy
    Groovy
    All the front suspension is painted Volvo Gray... IMG_2191.JPG IMG_2192.JPG IMG_2193.JPG IMG_2194.JPG IMG_2195.JPG IMG_2196.JPG
