Projects United Pacific 5W Deuce Build
Discussion in 'The Hokey Ass Message Board' started by Groovy, Feb 18, 2017.
  1. Do you have any photos where you drilled to install your shroud? I don't want to make a mistake and punch a hole in the wrong location.
    Four hex head, slotted sheet metal screws with washers on each side.
    The side frame on the Walker radiator is about 3/8" or 1/2" wide. Those core tube's behind the frame can't pass air, so they are made to not hold coolant, which provides area to mount a shroud.
  2. Groovy
    Groovy
    Thank you pprather... I will start making my template now I know how to properly install it.
  3. RockyMtnWay
    RockyMtnWay
    PM’d you with a couple pics.
