Art & Inspiration UNIQUE DASH KNOBS
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Apr 23, 2021.
  1. I have always liked seeing guys that use knobs from different makes & models to create a interesting dash, I have also seen mismatched knobs where something has been added later.
    I have also seen guys make their own knobs which really are impressive,
    Lets see what you hot rod and custom guys have come up with. HRP
    32SEDAN, 3W JOHN and dana barlow like this.
  2. I used some cabinet knobs that I though had a bit of a deco look to them.
    Sandgroper, 31rat, i.rant and 11 others like this.
  3. When I was building the wagon I redesigned the dash but wanted to stay with the original '54 dash knobs, since I was rearranging the knobs I sought out a few extra knobs and set about to make the air conditioning knobs look like they were not a after thought.
    This is what the controls looked like when I installed it and it just looked out of place.
    This is with the '54 Ford dash knobs, not perfect but a improvement. HRP
  4. This is a work in progress for my Chevy truck. First, I made the Tiger Eye T-handle style shift knob and liked it so much, I decided to make dash knobs to match. A new harness was going in but had to wait while I searched hard for this vintage chrome bezel to mount the switches to get everything working. Then I had to find just the right, matching Tiger Eye gemstones to replace the bill** knobs. I figure I'm about 90% done so by summer, I should be singing in the kitchen. :rolleyes:
  5. 1930ModelA
    1930ModelA
    hfh, 32SEDAN, Chris Nantus and 9 others like this.
  6. alchemy
    alchemy
    Knobs and escutcheons from a 50's Chris Craft boat.
    hfh, Tman, kadillackid and 6 others like this.
  7. 3W JOHN
    3W JOHN
    I used readily available 1940 Ford standard reproduction knobs on my 3 window.
    hfh, 32SEDAN, Desoto291Hemi and 12 others like this.
  8. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    I'm out of luck for the cool all matching nob thing,only have one nob,an that works the lights<even has a picture of a light on it !
    I did add a few years back a tiny little button key pad,luck it is small an most don't even see it. Had to do it,as my local radio station stopped playing my 1955 to 1965 records= I had too put in a chip player hiding up under dash with 2-- 8in. speakers,has 200 rock n roll 1955 to 65 songs. It dose beat my old transitor with ear plug an 9volt bat. But can't find were an when is the sock-hop!
    3W JOHN, Desoto291Hemi, Tman and 2 others like this.
  9. Dave Mc
    Dave Mc
    i.rant, 3W JOHN, vtx1800 and 6 others like this.
  10. Cheeta
    Cheeta
    My DSCN2138.JPG My homemade dice turn signal knobs.
    hfh, 3W JOHN, 32SEDAN and 5 others like this.
  11. Kiwi 4d
    Kiwi 4d
    Acrylic grapes turned down ,also the door locks . This was the owners idea ,my wife. Tricky little buggers to turn down due to the wire inside and inherent cracks. She still has ideas of resin casting some clear blue tiki style knobs . Just need to find the right size small tiki to use as a pattern. Hint hint >>>
    16079B18-EF91-4C46-9224-5F7C8BEA8FF2.jpeg 3B36FE83-162B-44D5-9B9D-1FD3E1D7C9FD.jpeg
    RICH B, 3W JOHN, dana barlow and 4 others like this.
  12. That's a great looking dash, the VW knobs are simple but they just work with your dash. HRP
    3W JOHN likes this.
  13. olscrounger
    olscrounger
    Lots of great ideas. On 40's I use the stock type knobs for all control but buy the ones with a stud for aftermarket lighter. Then stick stud to grinder-gets hot-pull it out. Now I have knobs to adapt to all switches and controls--also sand the dot off the end and repolish-have a bunch around here for next 40 whether std or dlx
    3W JOHN, hotrodA and HOTRODPRIMER like this.
  14. [​IMG]
    same for dash knobs and heater box doors
    hfh, 3W JOHN, dana barlow and 3 others like this.
  15. hudson48
    hudson48
  16. koolbeans
    koolbeans
  17. x77matt
    x77matt
    British sports car theme- Lucas Jaguar/ Land Rover switches with brass tags and an Austin Healey 3000 choke...
    B2093CD9-8149-48E4-B29B-80E9259FC166.jpeg 3CD6A092-E27A-42AE-B436-29D790E154B8.jpeg 8B5055BA-AB20-4B14-B576-B164058B1821.jpeg
  18. 3W JOHN
    3W JOHN
    I really like this look, reminds me of a early sports car dash.
    Max Gearhead and HOTRODPRIMER like this.
  19. goldmountain
    goldmountain
    It's not just the knobs but the control cables they attach to. I like to use ones from a 1964 Valiant because I owned one and liked the black trim ring that had white letters which labeled what the thing controlled. Unfortunately, scrap '64 Valiants aren't as plentiful now IMG_1108.JPG as when I began doing this.
    3W JOHN and HOTRODPRIMER like this.
  20. tiredford
    tiredford
    from Mo.
    OK my car is just a driver ok. My new headlight switch was that ugly billet switch that comes on most of the after market knobs. So I used the black cap of a WD 40 can, filled it with black silicone and stuck it on the billet knob. I don't have a picture but in looks like a old knob, much better I think.
  21. I have seen small tiki door lock knobs (pull up / push down) around the place. Looks about the right size to cast into resin.
    3W JOHN, HOTRODPRIMER and Kiwi 4d like this.
  22. There is something about the simple white or black knobs. HRP
    3W JOHN likes this.
  23. Looks like late model Mopar gauges also. Care to expound on this without derailing the thread?
    HOTRODPRIMER and 3W JOHN like this.
  24. Yeah, if you look at 'miniature' drawer/cabinet pull knobs there's quite few choices. Can be a bit of a PITA to mod into dash knobs in some cases, but no worse than any home-made knobs.
  25. 3W JOHN
    3W JOHN
    Yes.
    HOTRODPRIMER likes this.
  26. goldmountain
    goldmountain
    It has a '71 Valiant- Duster speedometer from an old tech week thread by mj40's, if I remember correctly.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  27. uncleandy 65
    uncleandy 65
  28. goldmountain
    goldmountain
    I just saw another example of this in the classifieds - gmc1941 is selling a '40 Ford pickup with this gauge setup. Works great.
  29. 3W JOHN
    3W JOHN
    Those VW knobs are nice.
    hfh and HOTRODPRIMER like this.
  30. [​IMG]
    Are they all the same? the 3 lower ones look flat in this photo.
    Looks simple & clean. HRP
    3W JOHN likes this.
