Unique, Custom, Handmade brackets post here
Discussion in 'The Hokey Ass Message Board' started by nitrohonkey, Mar 13, 2010.
  1. I get the biggest kick out of non "cookie-cutter" bracketry on hotrods... so I thought it would be cool for people on this site to show off their creativity and ingenuity here. So lets see what y'all come up with!:D
  2. langy
    langy
    i'll start you off
  3. Steve - was that engine mount bent or fabbed?
  4. langy
    langy
    Welded Geoff, it wasn't laser cut either like some think, It was cut out of 3/8" stainless plate with a thin cutting wheel and ground and filed to shape :(
  5. Antny
    Antny
    from Noo Yawk
    Beautiful parts, and welds! Dayum!
  6. Black Primer
    Black Primer
    Brake pedal and M/C frame mount I'm making right now. It uses the stock 1940 pedal.
  7. striper
    striper
    Fuck it...you win
  8. Great thread topic! Always great to see the details.
  9. Fatbrosracing
    Fatbrosracing
    from Australia
    Belt guard, line clamps, accelerator linkage, not that special compared to other stuff on this site, but I made them.
  10. Lets see more!!!
  11. BenW455
    BenW455
    Nice work guys.
  12. Made this alternator bracket for a Chevy motor with Voetec heads.
  13. CJ Steak
    CJ Steak
    from Texas
    This might be a painful question... but how many hours do you have in that mount?? That looks like it took a lot of work.
    Very nice.
    -Chris
  14. demented
    demented
    from Sweden
    Realy nice, true craftmanship.
  15. badshifter
    badshifter
    Since you didn't specify what kind of brackets...just made this yesterday for the kids tree swing...... Have at it O/T police.
    And just did a chain drive jockey shift on my air cooled project...
  16. zmcmil2121
    zmcmil2121
    I agree.
  17. nice chain shift!
  18. mj40's
    mj40's
    I could not afford some of the serpentine drive systems so I built my own. I already had the crank pulley, water pump pulley and alternator pulley. When I decided to add air conditioning I built my own mount for the air pump and then found a belt tensioner for the driver’s side and built a mount for that also. I had to replace the water pump with left rotation unit and mill the grove out of the water pump pulley. When it was all done I powder coated the brackets. I have just about $100 in my system.
  19. choppedtudor
    choppedtudor
    I'll add my headlight stands, I got mixed reviews from the 'traditional' crowd. 304 stainless tigged and polished.
  20. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    These are some of mine. One is a bracket on my roadster frame that mounts the shock, is the base for the aero tube that hold the head lights and also holds the radiator. The other pic is of the brackets I made to install a steering reducer to slow up my Schroeder steering box.
    Rex
  21. langy
    langy
    Thanks for the comments, Not too painfull :) It didn't take as long as you might think, first the shape was marked on a hunk of 10mm (3/8) stainless plate, where the radius's are I drilled holes and did the big holes with a holesaw, Then i cut out the shape with a thin cutting wheel in a 9" grinder handheld, To mark out and drill and cut out was about 3hrs, blending and fettling another 2 hours, finally polishing was around 3hrs.
  22. Looks really nice Langy.
  23. langy
    langy
  24. choke
    choke
    Here's a bunch of custom brackets I had to fabricate all over this project. they are all made of 4130 material.
  25. choke
    choke
    Having a hard time loading pictures, but here's a few more.
