I'm doing the clutch on my 62 falcon in the next week or two, but can't find any u-joint u-bolts that fit and they don't look like they will come off in one piece. The bearing caps are 1" and the smallest u-bolts I can find are 1 1/16". I've called a few local driveshaft shops and some independent parts stores with no luck. Does anyone know where i can find some?
Here you go http://www.jcwhitney.com/dorman-uni...e/p3051734.jcwx?filterid=c3671d616y1962g2u0j1 Be sure to talk to a rep to make sure the size is correct
http://www.falconparts.com/ford-falcon-auto-parts/pc/1960-1965-U-BOLT-FOR-U-JOINT-PAIR-61p323.htm Ask and make sure that they are the correct ones before putting out money though.
I found some locally at carquest. He said they were old and dusty. It was the 15th place i called, but i was looking at 20 bucks with shipping from falcon parts, and that seemed a bit silly for two dinky little bolts
