Hot Rods Turns over but NO SPARK ... HELP
Discussion in 'The Hokey Ass Message Board' started by olds vroom, Jun 4, 2015.
  1. olds vroom
    olds vroom
    I have an 86 sbc 305 it turns over but no spark . I have power to the distributor and I've already replaced the coil what am I missing? Help!
  2. Jalopy Joker
    Jalopy Joker
    HEI? post pics of motor
  3. jimcolwell
    jimcolwell
    from Amarillo
    Remove the module, take to perilous and have it checked 3 times. The best module is the GM brand. Others will fail.:D:D:D:D:D:D:D:D:D:D:D:D:D:D
  4. jimcolwell
    jimcolwell
    from Amarillo
    I hate spell check Oreillys
  5. olds vroom
    olds vroom
    Yes it is hei . I got the motor out of a running truck so I know it ran good but now no spark
  6. If its an HEI,
    1 check the rotor/ cap. They will arc thru the cheap rotors to the weights
    2 check the pick up coil with a meter( the wires brake cuz the advance moves them)
    3 have the electronic thing(forgot the name of it) in the bottem tested
    If its points, replace the condenser and check points
    SanDiegoHighwayman likes this.
  7. Master of None
    Master of None
    I would just pick up a new module, but first check to see which one you need. There is a couple of different styles. Also check all of your grounds, most likely isn't a grounding problem, but it will help in the long run.
  8. harpo1313
    harpo1313
    from wareham,ma
    Theres two plugs,ignition and tach.just checking off the easy stuff.
  9. olds vroom
    olds vroom
    The power plug is in the right terminal but thanks I've done that one before
  10. stimpy
    stimpy
    full blast has it on the money as thats all in a HEI the third thingy is the module . and make sure you put the paste back on it if you remove it , unless you want to replace it in a few weeks . besides AC delco modules Acell makes a decent replacement one too ( and has a better high rpm dwell ) . the pick up coils are the number one problem followed by the arcing thru the rotor assy ( you have to look very carefully as usually its a small pinhole ) . and buy the good cap and rotor from Ac delco or Acell as they are thicker .
  11. My money is on the module being bad.
    It can go bad if you have power to it for a while without the motor running .
  12. olds vroom
    olds vroom
    I'll get a module today
  13. olds vroom
    olds vroom
    I put a new module in and it fired right up thanks guys
    volvobrynk likes this.
  14. Thanks for the follow up post. People seldom do it but it helps others in the future when they are searching the archives.
  15. olds vroom
    olds vroom
    I find that too that's why I try to remember to do a follow up
  16. jimcolwell
    jimcolwell
    from Amarillo
  17. olds vroom
    olds vroom
    I be burned through two more modules and a new coil any more ideas ? Is it just time to replace whole distributor
  18. jetnow1
    jetnow1
    from CT
    1. A-D Truckers
    Did you use the paste as mentioned above?
  19. olds vroom
    olds vroom
    Yes every time cleaned the old paste off and put on new
  20. Do you have a resister in line? If you do take it out. You may be having a low voltage problem. Carl
  21. olds vroom
    olds vroom
    No resistor , I have a new distributor coming tomarrow we will see if that fixes it
