Technical turn signals
Discussion in 'The Hokey Ass Message Board' started by aircoup, Feb 19, 2018.
  1. aircoup
    aircoup
    hi my 56 f100 with a tilt gm steering column , blinkers dont work unless the test light is being used in the specific wire , creating a ground , obviously , and one side of flasher feed wire to turn wire doesnt have sufficent power unless engine is running , i know sounds real screwy any suggestions
  2. Try the traditional signals. :D HRP
    And of course the ever popular "Your number 1"
    sidevalve8ba likes this.
  3. So, they're just not flashing, but they are lighting up? Using LED lights anywhere? With the limited info, I'd guess either bad grounds at your light sockets or a bad/wrong flasher.
  4. Also, if the column has an integrated hazard light switch make sure it is off as it disables the indicators. This had me chasing my tail with my indicator setup for a while.
  5. I chased my tail with this myself. HRP
  6. DDDenny
    Another missed Kodak moment!
    Johnny Gee likes this.
  7. TerryT35
    TerryT35
    from Minnesota
    Fiberglass fenders? Have a separate ground wire?
    Fresh paint? Have star washers?
    Try a different flasher? Is it heavy duty?
    Just a few thoughts to consider.
  8. dan c
    dan c
    is your brake-light switch still wired to the tail lights?
  9. oj
    oj
    You aren't joining up the front and rear circuits at the column are you? Front and rear turn signal don't work together, people join them and the first problem is the circuit resistance is all wrong for the capacitor. Then they try the brake lights and things go sideways then.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
  11. aircoup
    aircoup
    thanks guys i got it figured out
  12. what was it?
