Technical turn signals flash fast
Discussion in 'The Hokey Ass Message Board' started by robtlor, May 23, 2016.
  1. robtlor
    robtlor
    from Lincoln NE
    My turn signals flash fast, 1157 bulb in front, 1004 bulb in rear, flashers says for 2-6 bulb setup. Any ideas as to the problem? Thanks for the help. Bob
  2. squirrel
    Some flashers flash fast if they don't have enough load, they are designed that way to make you realize there is a burned out bulb. If the bulbs all light up like they should, then try a different brand of flasher.
    OLSKOOL32 and rfraze like this.
  3. FANTM58
    FANTM58
    Yep that's been my experience as well,
    Usually means a burned out bulb
    In the system .
  4. H380
    H380
    from Louisiana
    They did make HD flashers. I had a F100 that when I plugged in trailer lights. The stock flasher blinked so fast it looked like the lights never went out. I put in a Heavy Duty flasher and without the trailer hooked up it sounded like a BIG relay switching. No BS I could feel the click through the steering wheel.
  5. 302GMC
    302GMC
    from Idaho
    1004 is a dome light bulb. Try 1034 or 1157
  6. Don's Hot Rods
    Don's Hot Rods
    from florida
    Yep, it's the flasher. Put a regular duty one in place of the heavy duty and it should slow down. I agree about that 1004 bulb too, why are you using that one ?
    Don
  7. Ron Brown
    Ron Brown
    What Don said, use regular not HD flasher. Also, if its flashing too slow change to HD unit.
  8. Maybe I'm missing something; but the regular old flashers I am used to have a bi-metal strip in them. Flash too fast = too much load. No flash = bulb burned out. Don't know about the modern electronic ones.
    I'd try a different brand flasher first thing.
    bct likes this.
  9. Don's Hot Rods
    Don's Hot Rods
    from florida
    Ya know , Rich, I am rethinking my post. I could be backwards on my thinking. But I do agree to see what kind of flasher is in it now and go to the opposite one. That bulb is also a question mark.
    Don
  10. Truck64
    Truck64
    from Ioway
    Do they make a louder click type flasher? Or does the HD version pull double duty in that deal. I kinda like that old school tink-tonk.. tink-tonk.. When did that start, anyway? 50s?
    None of you folks were ever smart enough to discover as a kid I'm sure, if you simultaneously pressed the brakes and had the four way flashers on, the radio would work intermittently. And if you first ran a breath or two back through a cigarette butt, they tasted pretty fresh.
  11. I don't know what the numbers match up to but the wattage of each bulb should be 21 watts. JW
  12. I think you used to hear the flasher click on the older cars because they were mounted in a metal bracket which in turn was attached to the metal structure under the dash; kinda became quieter when they started putting them in the fuse panel.
  13. Truck64
    Truck64
    from Ioway
    Mine is still installed in a metal bracket under the dash, but have dual exhaust and Porter steel pacs.. I thought there were "loud" versions of those things. Maybe not.
  14. I have the loud version. It still ain't loud enough! Car is quite.
  15. KevKo
    KevKo
    from Motown
    I have a Speedway wiring kit in my F-100. My signals start flashing fast, then slow down. All bulbs are normal incandescent except the turn indicators in the dash are LEDs. I wonder if that is the issue.
  16. On newer cars, definitely a gimee that a bad bulb makes them flash faster. Older cars I recall the signal indicator lighting up on the dash, but it wouldn't flash if a bulb was bad. I use 1157 bulbs in everything. My Ford had those 1034 bulbs in it when I got it.
  17. plym_46
    plym_46
    from central NY
    Also check that all your grounds are adequate. Sometimes it takes a dedicated wire, A jumper wire with a couple alligator clips will easily test the theory. I found I had to do this on my Studebaker pick up as the mounting of the bed did not provide a reliable ground path to the frame.
  18. mrspeedyt
    mrspeedyt
    as to flashers... i would like my turn signal lights to immediately light up when i just barely hit the turn signal lever. i do not like the wait (i know it's a second or two) for the bulbs to light up. my ot scion lights the bulbs immediately when moving the lever.
  19. H380
    H380
    from Louisiana
    O'reilly $11.49
    Novita Technologies - Hazard Warning/Turn Signal Flasher
    Line: NOV | Part # EL12
    DETAILED DESCRIPTION
    The Novita EL12 is an electro-mechanical turn signal flasher that operates at 12 V. This type of turn signal flasher uses electro-magnetism to operate and lasts 10 times longer than conventional thermal flashers like the 552 and 536. The EL12 is capable of handling additional lamp loads due to trailering and is proudly made in the U.S.A.
  20. When I installed turn signals on my cabrio, I was using LED lights and they require a special flasher.
    Don't know if this will pertain to your issue.
  21. 54 Chevy
    54 Chevy
    You can use the new Electronic flashers with LED or original style bulbs. They don't care what the load is from my experience. You can get them at any parts store.
  22. The LED items have a resistance circuit. JW
