turbo 350 question
Discussion in 'The Hokey Ass Message Board' started by mikyboy, Apr 6, 2010.
  1. mikyboy
    mikyboy
    I'm not running a speedo .Is there a threaded cap to block it off at the trans where the speedo screws into? I used a piece of dead end heater hose (it leaks)but I was wondering if theres something better,what do you use?
  2. squirrel
    Take out the "slug", and put in a freeze plug the right size? Or just replace the seals, it should not leak.
  3. 33_chevy
    33_chevy
    from TX
    I think there is a fork looking bracket that has 1 bolt when you remove the bolt you can pull the plug that's got a gear on the end,replace the O ring around it and that should stop the leak.You don't have to run a speedo..and it should not leak with out a speedo
  4. Steve
    Steve
    exactly mine does not leak without a speedo cable attached.
  5. Deuce Roadster
    Deuce Roadster
    There is a " O " ring on the bullet.
    The bullet is held in place by a small metal tab
    REPLACE the " O " ring :D
    They are about a dollar ... or so
    Leak solved.
