Technical Turbine paint system for primer
Discussion in 'The Hokey Ass Message Board' started by sf_hippie, Oct 29, 2019.
  1. sf_hippie
    sf_hippie
    Hi. I am working on my first restoration. I want to strip the paint off of the car and take care of all of the body work and priming. I will then take it somewhere to tell me what I messed up and to finish the final paint. My question is if a turbine hvlp system will be good enough for primer in my garage, or if I should get a compressor system. I was just worried about cost and space so that is why I was looking at the turbine systems
  2. 27 Tall T
    27 Tall T
    from Butler Pa.
    I have one TP Tools ,and like it alot
    Dino 64 likes this.
  3. Doesn't answer your question but I would try and find a shop that will paint over someone else's work before I got too far along if you are not prepared to do the final paint yourself. Most shops will not do it. They have no way of knowing if what you did was right and it is their reputation on the line if it fails down the road.
    62rebel, da34guy and Nailhead Jason like this.
  4. X2 what he said ^^^^^^^^^^
  5. Budget36
    Budget36
    I've never used a Turbine system, so no advice there. But consider the cost of it as a "specialty tool" that can only be used for one thing, versus the cost of a good compressor that can run your airtools needed while doing your prep work and run the gun you use to spray the car with. Consider a vertical standing compressor to take up less of a foot print in your garage/shop.
    Also, I might add, when I was looking at Turbine systems, seems you are kinda stuck with the spray gun that works for that system-someone will correct me if I'm wrong.
  6. bchctybob
    bchctybob
    Budget36 has a point. The turbine system is pretty much a one trick pony whereas a good compressor does more.
    I sprayed primer with my turbine setup with great results, first try. There is a thread on here that’s full of good info about systems, guns and tip sizes. Do a search.
  7. Blue One
    Blue One
    from Alberta
    As far as I’m concerned the turbine system is the only way to go.
    Clean dry warm air and consistent pressure.
    I used a 5 stage turbine and a Fuji turbine gun to paint my RPU single stage acrylic urethane.
    More details in the painting at home thread or in my build thread.
    1F1FECC1-BE23-4602-B4AA-C3B428E0AA85.jpeg 8F601D48-EA96-4ACE-8739-48862CFC8C2B.jpeg 10FCE9AF-C6CF-4DA3-BB30-998AF0E875B4.jpeg 16EF6CED-1243-43AF-8794-0C294B977AA4.jpeg 7540197F-6D1D-4675-B4E1-0C74C62D8110.jpeg 6F6BF8E7-F08A-49AF-A46A-A3944437D7D7.jpeg 353E658A-4763-43C1-AA82-AA5BB0A925A1.jpeg 17C630BA-E9C3-427A-9943-CA8B9D69700B.jpeg
    Packrat, catdad49 and Dino 64 like this.
  8. 62rebel
    62rebel
    By the time you get good with primer you will be good enough for final color. I've met professional painters... you'll be fine
  9. Dino 64
    Dino 64
    from Virginia
    Thinking of getting their unit, how many stages is yours ? Did you use a clear coat ?
    Sorry don’t mean to high Jack your thread
  10. southcross2631
    southcross2631
    I saw a 57 Belair that was painted black with a turbine paint system and it was really nice.
    Thought about trying one out .
  11. 1ton
    1ton
    I've been interested in the turbine paint system for years. Never tried one but would like to. For me, it boils down to giving up the floor/shelf space. I value every square foot of space dearly. I realize that the unit is not large but I feel that it's not worth giving up the space for what I'm going to consider a luxury item. The compressor works fine.
  12.
  13. I did my 1st paint job in the garage using TP tools turbine. You have to use their guns due to the fittings. I got major orange peel till I reduced the paint about 5 percent more then called for. [​IMG][​IMG]
    Dino 64 likes this.
