Hot Rods Tungsten sharpening
Discussion in 'The Hokey Ass Message Board' started by flatford39, Jun 29, 2020.
  1. flatford39
    flatford39
    Going to try my hand at TIG welding after years of MIG. I got the basics down I think but I would like to know what you guys are using to sharpen the point of the tungsten. Seems like a critical path to me.
  2. Jmountainjr
    Jmountainjr
    I tried about every possiable way for a number of years before finally getting a tungsten sharpener. I find it faster and much more convenient and consistent.
    ottoman likes this.
  3. squirrel
    I use a very old little grinder that has a fine stone, that I keep well dressed. It just takes a few minutes to learn the technique.
    You want to sharpen it well, but it's really not going to keep you from welding if it's off a little bit.
  4. seb fontana
    seb fontana
    from ct
  5. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    I have a belt sander that I use to sharpen the tip
    ct1932ford and ottoman like this.
  6. I use a tungsten grinder as well. So much more convenient. You can have it right beside you when you are welding so if you have sharpen in the middle of some work you can do it right there and not have to disturb what you are doing to get up and go over to a grinder.
    ottoman likes this.
  7. rusty valley
    rusty valley
    i use a fine stone to shape it, and a cheap diamond blade from HF to finish it. the little blade is 4" flat thing made for sharpening carbide saw blades, cheap, like 12 bucks or so, i mounted it on the outside of the stone
  8. squirrel
    I keep 5 fresh tungstens with me, so I dont have to get up and grind quite so often :)
    A good welder would only need to touch it up occasionally, but that's not me.
    warbird1, catdad49, ottoman and 5 others like this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    I use a bench grinder with a fine wheel that I don't use for anything else. I keep a few tungstens sharpened with me also, and I sharpen both ends so I can just turn em around....
    catdad49, cactus1, alanp561 and 2 others like this.
  10. Marty Strode
    Marty Strode
    Me too.
  11. I use a green wheel for carbide.
  12. Lloyd's paint & glass
    I don't own a Tig machine the days, thanks to an ex wife, but i had a fine stone on my bench grinder, and i would chuck my tungsten up in the battery powered drill and spin it while i put it against the stone.
  13. big duece
    big duece
    from kansas
    jvo and squirrel like this.
  14. woodiewagon46
    woodiewagon46
    from New York
    If you are using 2%, Thoriated (red tipped) tungstens, just be aware that the dust produced by sharpening is radioactive and can be harmful if ingested into your mouth, nose, lungs etc. Thorium, (Th) atomic number 90 is a proven carcinogen. Always wear gloves, a respirator and safety glasses. We had a dedicated grinder that had a vacuum catch bag and once a month it was removed and sent to a hazardous waste facility. Also, don't sharpen both ends of the tungsten to save bench time. Once you remove the identifying color band you will have no way of knowing what tungsten you have.
  15. noboD
    noboD
    Big Duece is correct, dedicated wheel. By the book there should be a small flat on the very end, not to a point.
  16. alanp561
    alanp561
    OK, the topic is sharpening tungsten. On both fossil fuel and nuclear powerhouses when I was welding high pressure heavy wall tubing, we would chuck up our tungsten in a drill motor, fire up a 4 1/2 inch grinder, point the tungsten in the same direction as the grinder was turning and grind the tungsten to a needle point, 3/8 " long, for carbon steel or stainless. We would not use the same grinding wheel or tungsten for both metals to avoid carbon contamination of the stainless. If you use tungsten that has been used to weld carbon steel to weld stainless, your weld will rust. If you use the same grinding wheel on both carbon and stainless, the stainless will rust. If we weren't sure about what the last material the tungsten was used for, it got trashed. We used up lots of tungsten but we didn't have any welds fail because of carbon contamination.
    cfmvw, 41 GMC K-18, catdad49 and 5 others like this.
  17. Oh Crap! After doing it wrong for 40 years I suppose now I'm going to die. I thought the dust bag was for the Shop Vac.
    alanp561 and dirty old man like this.
  18. gimpyshotrods
    gimpyshotrods
    I have a small bench grinder, with fine stones, bolted to the top of the TIG welder. I only sharpen Tungsten with it.
    warbird1, cactus1 and big duece like this.
  19. 1946caddy
    1946caddy
    from washington
    A lot of good suggestions. I'm going to add that I use a cordless drill motor to spin the tungsten while sharpening them on a dedicated 6" bench grinder.
    alanp561 likes this.
  20. alchemy
    alchemy
    I do it like Big Deuce, but my dedicated stone has a slight groove down the center now which makes slowly spinning the tungsten easier to make a point.
    I have a LOT of experience grinding tungstens. Not because I weld a lot, but because I can sure stick the tungsten into the weld.
  21. rusty valley
    rusty valley
    you are not supposed to spin the tungsten that fast. the electrons flow off the point in a straight pattern, this is why most photos folks have shown show the tungsten running straight onto the grindstone, not spinning
    saltracer219 and gimpyshotrods like this.
  22. gimpyshotrods
    gimpyshotrods
    Yeah, I was raised to never do the drill thing. Just fingers, and slowly, at that.
  23. j hansen
    j hansen
    from sweden
    I made a support thing, Skärmavbild 2020-06-30 kl. 07.02.33.png so I get the "right" angle.
    big duece and gimpyshotrods like this.
  24. I have a cheap HF 6in grinder bolted to my welder, course and fine stone works for me.... Fire ext locations (5).jpg
  25. 1946caddy
    1946caddy
    from washington
    Been doing it that way for over 40 years and never failed a certification so far. Maybe I'll start spinning them counter clockwise to make up for my evil ways.
    https://www.weldingtipsandtricks.com/sharpening-tungsten-electrodes.html
    Pist-n-Broke and ct1932ford like this.
  26. flatmotor40
    flatmotor40
    from georgia
    Bought one from Eastwood for tungsten grinder hand held and diamond disc.Think it was $79
  27. Graham08
    Graham08
    6" grinder with a fine stone here. If I really mess up the tungsten with a big blob of molten steel or aluminum, I'll cut the contaminated bit off with a cutoff disc before re-dressing the tungsten.
  28. flatford39
    flatford39
    Thanks every boby for all the great information. I guess I will use my bench grinder as shown and see how it works.
  29. HRBOB34
    HRBOB34
    Lots of good information!
  30. squirrel
    sounds like a lot of work, compared to just breaking it off with a light hammer blow, over the edge of the bench. :)
