Projects Tucks 29 Roadster Build ---->
Discussion in 'Traditional Hot Rods' started by Tuck, Aug 26, 2013.
  1. Kan Kustom
    Kan Kustom
    Man, that Hemi is beautiful even without the valve covers !
  2. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Totally agree-
    Lucky for me my shop has 3 phase-!
  3. fourspd2quad
    fourspd2quad
    Very nice collection of machinery! Looks like they are in the right hands. Nice work BTW.
    31chevymike and Tuck like this.
  4. impressive Tuck! Can't wait to see what you turn out on those
    31chevymike, Tuck and vetteguy402 like this.
  5. 31chevymike
    31chevymike
    Wow Tuck, just went through a few hours of completing this thread - NOW I understand why you've been away from the Star Destroyer! You're building skills are exceptional, even more inspirational that I did not know you had a shop fire... Still finding the time and determination to finish your roadster with the real time to raise two beautiful young daughters with your wife! Absolutely crazy about this roadster build!!! Subscribed!!!
    Outback, chryslerfan55, brEad and 4 others like this.
  6. loudbang
    What Chevy Mike said said ^^^^^ :)
    enloe, ls1yj, Tuck and 1 other person like this.
  7. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Aw man, thanks Mike! Seriously cool of you to say- the struggle is real!!! (-;
    it's almost Christmas break hoping to get some time in the shop so I can update this post-!!
    I got the parts I needed for the mill- it just needs to be wired. I cleaned up all the handles and bolted em on- replaced some of the broken ones... the x axis bushing had slipped out- fixed that- x,y and z are working...
    My father in law hooked me up with a five gallon pale of tooling, hold down blocks, v blocks, step blocks and a bunch of other goodies-
    Still missing some small stuff the the x-axis power feed- the electric motor is missing the housing and there is the linkage that goes to the lever. Hoping I can track those parts down. This thing is so cool!!!
    Can't wait to use it this weekend!
  8. Tuck, I must ask......are you so disciplined that you use that time clock:D:D:D
    Just stoked for you and all your new machines man! Christmas break=fun in the shop!
    Outback, Stogy, chryslerfan55 and 4 others like this.
  9. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Ha-Thanks man-!!
    I do use one, but not for my jobs. I have a car I'm working on for someone else that I log hours on but it would be cool to collect data on how many hours I actually log working on the roadster... because you tend to inflate or deflate the actual time in your head. It might help me be more productive?!?
    Stogy, chryslerfan55, brEad and 2 others like this.
  10. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    I didn't take many pics but here's what I got done. I milled 1/4" pockets on the back side of my bone mounts so I could get cotter pins in the nuts. Nothing fancy but sure is rad having a mill in the shop wish I had this years ago.
    I milled drilled and tapped a piece that a 40 ford z-bar ball mount bolts too so my clutch linkage is almost done.
    I finished the rear drum clearances to the drums on the Lathe. When things bolted up they didn't mount flush on the back- it required 1/4" spacers to clear the hub center. I cut more out of the outside ring to clear the backing plates. I also ordered a set of lugs that might be just fine- I'm on the hunt for mag shank acorns with a .68 dia shank like pictured on the mag- I got 9 of them from Sam-I-am.
    I bought some NOS super ET center caps.
    I did a bunch of welding on the rear bones and some on the chassis. Passenger side front bone in finished grinding the welded seam on the bottom.
    My goal is to get most of the chassis/suspension stuff finish welded so I can put it back together again and finalize the placement of the trans mount... as I ended up having to remove the clamps that held it in place.
    I wanted the wheels and brakes sorted.
  11. 31chevymike
    31chevymike
    You're moving along quite well Tuck! Happy New Year to you and your family!
    Tuck and loudbang like this.
  12. TexasSpeed
    TexasSpeed
    from Texas
    Keep going, man!
    loudbang, 31chevymike and Tuck like this.
  13. Tim
    Tim
    from KCMO
    Texas is calling! Will tuck get to the phone in time?! Stay tuned!
  14. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Holding steady...
    loudbang and 31chevymike like this.
  15. I need some long shank acorns for my Raders. Is that not something readily available?
  16. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    You can get long shanks from the lug nut king but they don't make acorns like the old style acorns anymore... I have enough for two wheels but I'll collect a full set later and then re-chrome them. These mags were originally setup for 7/16" studs but I had to step the holes up using a couple reams so .68 dia mag shank lugs would work with the 1/2" studs.
    I needed a .55 long shank with a .675/.68 dia and they look like this. Not excited about them but they'll hold the wheels on until I find old ones. I got long shank originals with the right dia and cut them down to .55 on the lathe and those are in the pic above. I'll find some I'm sure via friends and swap meets. :)
    I feel like LONG SHANKS is a good pirate name. Short Shanks mmmm... not so much. haha-
    Outback, Stogy, ls1yj and 7 others like this.
  17. Runnin shine
    Runnin shine
    “Rrrrrrrrrrrr, Captain Long Shanks, me fear the bloody nuts be buried at the bottom of Davey Jone’s locker”
    Outback, Stogy, chryslerfan55 and 8 others like this.
  18. loudbang
    That one wins for today LOL had snot flying out my nose when I read it and laughed out loud. :confused:
  19. I've got a can of lug nuts I can look through to see if I have any. What do the old ones look like?
  20. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    MUCH SHANKS @cactus1
    on that pic a few posts above I posted pics of my firestone slick/mag with them on it... they have a round end and look like a real acorn from a tree. They still make acorns just not for the old mags... especially hard to find in 7/16" threads- 1/2 20 are much easier to find.
  21. brad2v
    brad2v
  22. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
  23. 31chevymike
    31chevymike
    Looks like you needed the spacers to allow the finned drums to stick out more from the slicks. This is exactly what I will be dealing with on mine, running the finned drums on all four corners as well. These hot rod wheels have specific back spacing that sometimes will not have the "right look" when combined with the finned drums. At times, the back spacing is not equal on front and rear wheels as I've learned on some wheel choices that I'd like to run. Those slicks are "KILLER" - never knew Firestone made whitewall piecrust ones!
    Outback, brad2v, loudbang and 2 others like this.
  24. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Thanks Man!!!
    Wasn’t fin interference- the hole in the mag wouldn’t fit over the axle center- and the drum weights would touch
    Outback, Stogy, ls1yj and 11 others like this.
  25. I love looking at the shop as much as the chassis! So happy for you dood!
    31chevymike, brad2v, loudbang and 2 others like this.
  26. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Thanks man! I get it all cleaned up like tonight and it seems so surreal- so Lucky to have this space and all my tools back- I only wish I had more time.
  27. enloe
    enloe
    from east , tn.
    Man this car is BADASS
    31chevymike, loudbang and Tuck like this.
  28. 31chevymike
    31chevymike
    I feel the same way Tuck - you're chassis is shaping up to be one of the BEST I've ever seen, more so that it's completely home built! The only other chassis that comes to mind in my opinion is the Wade Model A coupe built by Brian Bass!
    Have you or will you consider laying on some candy or metal flake paint on this chassis to compliment all the chrome plating you plan to do on this roadster? I'm asking because I'm planning to have this done on mine. I remember you saying that you wish other hot rodders would build more cars like the one's you are building - I'm one of them too Tuck!!
  29. Good work takes time. This will be a show stopper car. Killer detail.
  30. bryanyeskie
    bryanyeskie
    from Hixton
    I'd still like to see it in its current state! This guy knows what a real hot rod is...
