tube frame question
Discussion in 'The Hokey Ass Message Board' started by freebird101, Sep 1, 2010.
  1. freebird101
    freebird101
    I was wondering if any one knew what type of dimension tubing would be needed for something like this that I saw in the "Parts With Appeal" section in HRD
  2. freebird101
    freebird101
    anyone anywhere
  3. terry48435
    terry48435
    I can't see what you're talking about in the picture. It's too blurry.
  4. bigviking0001
    bigviking0001
    freebird...I can't tell what you are trying to build from the pic.....what is it and what is it used for?....
  5. '46SuperDeluxe
    '46SuperDeluxe
    from Clovis, CA
    Just a wild guess to draw in someone that really knows their s#!+ 3" dia x 1/8-3/16 DOM
  6. Buckster
    Buckster
    I would see what the section modulus is for a rectangular 3" X 2" X 3/16" wall tubing. Then select a round tube that has that same or nearly same value. That info can be found in an AISC Steel Construction Manual. The section modulus for the rectangular tube is 1.24. I could not find a catalog for steel tubing but a 3"standard wall (.216) pipe has a section modulus of 1.72. 2-1/2" XS pipe (.276 wall) has a section modulus of 1.34.
    You could do the same exercise for a 2" X 1-1/2" X 1/8" wall rectangular steel tube & still be safe. My catalogs did not have that size tube. A steel service center should be able to furnish that data.
  7. freebird101
    freebird101
    thank you, thats what i was looking for. What it was in the pic was a signal tube on each side running as the frame. I was asking because I was searching in dimensions and all I found were multiple tubes and was wondering if just one would work ok.
  8. SimonSez
    SimonSez
