Working on the trunk of my car. Just put new black carpet in with White panels. Should I leave the wheel tubs black or cover/paint them white Sent from my SM-A600P using The H.A.M.B. mobile app
This is the car. Most of the interior is white with black xarper Sent from my SM-A600P using The H.A.M.B. mobile app
That is a good looking 55, What motor are you running? Sent from my XP8800 using The H.A.M.B. mobile app
Looks fine as it is. However, you could make a removable white upholstery panel that fits smoothly into the corner, hiding the wheel wells. Use Velcro to secure it in place to the side panels and the rear panel. Make a template out of cardboard first. Then use thin door skin or regular upholstery panel card board to make the corner piece. You could also use sheet metal bent to fit either with a sharp bend or a smooth radius.
