Technical Trimming WIndshield Gasket - 1950 Ford
Discussion in 'Traditional Customs' started by Chop50, Jan 31, 2015.
  1. Chop50
    Chop50
    Anyone cut down a windshield seal for a chopped shoebox? My guess is that you would want to trim on both sides of the center seal at the top of the windshield then trim the center seal and glue back together with super glue? 3-cuts?
    Thanks, Steve
  2. martinautobody1
    martinautobody1
    from Ohio
    I quit doing that, and have been putting chopped glass with windshield butyl ( in a ribbon like used in the 60's
  3. tastylittlebox
    tastylittlebox
    from Missouri
    Check Big A's build thread... does the hamb really need another shoebox thread? is the title. It is in there somewhere. Really good read on a really slick kustom too. Worth the time.
  4. desotot
    desotot
    Steve use your best judgement, super glue works.
  5. atomickustom
    atomickustom
    I cut the bottom, not the top, on my chevy. If it leaks in the rain it will drip on you if you splice at the top.
    Super glue does work well.
