Trim clips, where to get them?
Discussion in 'The Hokey Ass Message Board' started by PeteMattersen, May 13, 2009.
  1. I have a 55 buick in the shop i just got done paining. Now its time to put trim on but the prior owner was a little hard on things when they dismantled this old girl. Anyone know where to find them?I need side trim and upper door molding clips.Its a special, 4 door sedan.
    over and out
    petemattersen
  2. manyolcars
    manyolcars
    make what you need
    cut a scrap of metal so it slides in your trim,
    drill a hole in the center, weld in a small bolt
    To be high class, use stainless with a stainless bolt
  3. Try Au-ve-co,
    Or the Buick clubs. I know a Buick Club member that has drawers full of new clips. PM me for his name..I don't want to put it out here without his permission.
  4. Butch11443
    Butch11443
    Ask a body man. You can buy a universal clip that you can trim to size with snips with the boly welded in quite reasonable.
    Butch
  5. temper_mental
    temper_mental
    from Texas
  6. oilslinger53
    oilslinger53
    from covina CA
    kanter has clip kits for most cars, or you could make them. time vs. money.
  7. choppintops
    choppintops
    X2. Used them for years.
  8. Shadetree
    Shadetree
    from Va USA
  9. skwurl
    skwurl
    I got my clips here for the Ols we're doing. Havent used em yet but thay have the best selection i've seen
  10. BrandonB
    BrandonB
    from nor cal
    Try paint shops. They usually carry a very large assortment of trim clips.
  11. TagMan
    TagMan
  12. I was considering this, but if i could just find them that would be ideal, they are pretty much all either missing or mangled.
    Wtf?
    Thanks for the info fellas, sounds like they are easier to find then i assumed.
  13. Special Ed
    Special Ed
    Restoration Specialties has what you need.
  14. 49 Custom
    49 Custom
    Thanks guys, for the sources! I've been getting ready to put '54 Buick trim on my '49 and didn't really want to go with plastic, either.
  15. Shadetree
    Shadetree
    from Va USA
    They worked out really good on mine!!!
    Real easy to trim to fit, with just tin snips, and they have a protrusion, on the back, so that you can trim back, for deep or shallow moldings. That way you can get a real tight fit.
    I am going to order some more, in case I finally find a set of rocker moldings for my 51 chevy!!
  16. Shadetree
    Shadetree
    from Va USA
    Just wondering why some of you guys are "anti-plastic"???
    I looked at several types of fasteners, and I reasoned (whether right or wrong) that these would be a lot easier to install, and remove, if you had too, and also wouldn't have the problem of rusting clips, bleeding down on the paint at a later time.
    I guess if a person was trying to build a car, to original specs, and with all original stuff, but I not at all, interested in "Restoration Scene". I am just trying to build a poor boys, driver.
    To each his or her own, of course!!!
    But was just wondering what your thinking on going "anti-plastic.
