how do i get the trico wiper motor out of my 19 ford f10?? cant seem to find any clips that connect the motor through the firewall.
Remove the 2 clips at the arms... don't lose the little buggers... and snake it through the firewall slot. Not like they give you a ton of room..
as Bob said lift the top of clip carefully then slide off.as stated this why pics help a ton I would spray a lube of some type to aid in removal due to rust and dirt
Took the wiper motor apart gave it a good clean and all working well, just need to get the correct blades now.
