Technical Trick Flow aluminum double hump heads
Discussion in 'The Hokey Ass Message Board' started by jbarker, Dec 23, 2018.
  1. jailbird
    jailbird
    I run a pretty good set of original double humps lot of time/$ was spent on them they are what they are true 60's I have nothing to compare them to they were on my blower motor but I now have them on my old 327 what would be a great choice of aluminum cheater heads for my .40 over 350 with a 6-71 im in the middle of putting the blower motor back together as soon as I get a set of heads.
    31hotrodguy likes this.
  2. kasselyn29
    kasselyn29
    Awesome car unbelievable effort Thumbs Up
  3. 1lucky1
    1lucky1
    from Morgan NJ
    Anyone else use these heads?
  4. old.hot.rodder
    old.hot.rodder
    Remember, Camel hump trick flow's are 60CC only. Great for flat tops, not so much so with domers with todays pump gas. They have great flow numbers for the money. I am pretty sure Summit owns trick flow.
    GlassThamesDoug likes this.
  5. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I been thinking bout Makin a couple double humps and soldering them to the heads on my 500 Cadillac engine.........figure that oughta be good for startin a few "discussions" at some rod runs. :D:D:D
    AHotRod, anthony myrick, Tman and 3 others like this.
  6. 32fenderless
    32fenderless
    Speedway offers them as well. [​IMG][​IMG]
  7. Roothawg
    Roothawg
    This is the Speedway flow chart.
    A Brodix Track 1 for comparison
    GlassThamesDoug and 402BOSSMAN like this.
  8. lippy
    lippy
    from Ks
    Just have some famous engine builder build you one all it takes is $:)
    ekimneirbo and 31hotrodguy like this.
  9. 54BOMB
    54BOMB
    This thread is new enough that I don’t feel bad bumping it up . Anyone here running the trick flow head that can tell me what length pushrod you used ? Iknow you need to check to make sure , but just for comparison.
    rbrewer and Deuces like this.
  10. DDDenny
    Pushrod length is determined by many component factors besides just the assembled heads.
    19Eddy30, egads and Deuces like this.
  11. I'm watching this thread. I will likely be buying a set of these heads in the next year. I e mailed Trick Flows tech dept and they have plans to start making these heads with a 62 cc comb chamber ( this summer?) not sure what other features.
    From a super chevy article /build using the dhc 175 heads ("For pushrods, we chose Comp Magnum pieces (PN 7644-16). Their 5/16-inch diameter was perfect for our Trick Flow guideplates and the 7.750-inch length was optimum for our valvetrain.") http://www.superchevy.com/how-to/1905-upgrade-the-power-of-your-gen-i-small-block-chevy/
    I agree that checking the push rod length is too important , than to rely on an article.
    Deuces and chevy57dude like this.
  12. 54BOMB
    54BOMB
    I saw that same article too , I was just curious on who was using what. I’ll have them on the engine this weekend and can measure for sure .
    Deuces and rbrewer like this.
  13. Cool- thanks for reviving the thread, good luck on your project!
    If your up to it, can you detail you build?( cam, pistons/ rings- compression ratio, head bolts( washers??) head gasket- maker and thickness? final quench?)
    I'd appreciate the info!
    Deuces likes this.
  14. 54BOMB
    54BOMB
    Large journal 327 , 5.3cc dome piston , .028 gasket . Schneider cam 284/294 duration 480 lift 108 lobe separation. I’m not sure about quench . I’ve been driving it with stock camel hump heads for 2 years , I wasn’t sure about these because of the 175 intake but they out flow the brodix Ik180 and 200 and have higher compression with the 60cc chamber . I’ve been using a Weiand dual plane from the 60’s but I’m going to try a edelbrock single plane now.
  15. 402BOSSMAN
    402BOSSMAN
    I did the flow testing for Speedway. They spent a day at my shop taking pictures while I was evaluating all aspects of these heads.
  16. Dave G in Gansevoort
    from Upstate NY
    So a question to clarify: Speedway heads, are they Speedway's own or TF heads? Either way doesn't matter, I've been a customer of Speedway since 1975 and can't say anything bad about them. Might be an interesting head for my 327 for the "Whatever" project in a year or two.
    Deuces and High test 63 like this.
  17. 402BOSSMAN
    402BOSSMAN
    They are a completely different head.
    Deuces likes this.
  18. alphabet soup
    alphabet soup
    Anyone know how the Speedway heads compare to the TF ones in flow?
    lothiandon1940 and Deuces like this.
  19. 54BOMB
    54BOMB
    the Trickflow head has better airflow. With the price of the heads being almost equal I’m not sure why people would buy the speedway. Unless they had some option that was needed . I’ve never seen the speedway heads in person or know anyone who has them, so maybe I’m missing something.
  20. alphabet soup
    alphabet soup
    That's a pretty good difference, if the prices are close. Thank you for posting the info! Gene.
    54BOMB, Deuces and lothiandon1940 like this.
  21. Roothawg
    Roothawg
    FYI, I just received a response back from TF. I asked if there was a set of 64CC chambers coming in the future. Here is their response:
    Hello Chris
    At SEMA 2019 TrickFlow had a demo DHC 200 head. This head has a 65cc chamber. Due to COVID all of the new products that where set to be released have been pushed back. At this time we are looking to have these released mid 2022 but this may change. The final casting and machining have not been approved by our R&D team yet.
    Thank you
    TrickFlow
    deuceman32 and kidcampbell71 like this.
  22. Roothawg
    Roothawg
    Talked to TF at the track this weekend. Looks like they have a good prototype for the 64cc. Should be going to production soon.
    Here’s a pic of the DHC-175. It’s a nice piece.
    B8655A49-5A40-4164-831E-A3D98CB8BDC6.jpeg 19197179-04C0-45BC-B1B7-BE31B0F578D6.jpeg
  23. Must be good, back orders at Summit. Imagine, if these perform as promoted, once these begin to catch on, the demand will be tremendous .. based on number of double hump engines in the market. That being said ...iron camel humps $$ are dropping fast.. in the $150 / set range at last swap meet..... they will be door stops in 2022.
    Deuces and loudbang like this.
  24. PotvinV8
    PotvinV8
    Just wish they offered them with a larger combustion chamber for those of us wanting to put a little "boost" into things. I have a set of their Super 23 heads with 72cc combustion chambers that I would swap for these on external appearances alone.
    loudbang and GlassThamesDoug like this.
  25. Roothawg
    Roothawg
    I spent $550 on my last set of 462's. They are in the attic wrapped up in plastic. I doubt I could get my machine shop bill back.
    Deuces, loudbang and GlassThamesDoug like this.
  26. lippy
    lippy
    from Ks
    Am I suddenly on the wrong site?
  27. Roothawg
    Roothawg
    Nope. Hot rodders go fast.
  28. Agreed....I built a 427 bbc engine for a friend, he gave me NOS 034 angle plug bowtie castings in the box, for the labor. Cost to put in usable condition...$2200. (they require valves, springs, studs, guide plates, then chamber work to bore size, unshrouding, bowl work, and flowed.)..... boat anchors... cuz too heavy to make wall hangers.
    loudbang and Roothawg like this.
  29. Magfiend
    Magfiend
    Looks like the Speedway ones are 64cc chambers...
  30. Now...how bout 283 270hp, 283hp fi, and 520 power pack clones..... small cube motors might be back...
    loudbang, 427 sleeper and Roothawg like this.
