Tri power linkage
Discussion in 'The Hokey Ass Message Board' started by model-a-fan, May 11, 2009.
  1. model-a-fan
    model-a-fan
    from Kentucky
    Can I see some pic.s of your tri power linkages? I'm having trouble figuring out how to set mine up. (Stromberg 97s on an Edelbrock intake)
  2. HotRodFreak
    HotRodFreak
    Easy to buy the complete progressive setup from Speedway, Charlie Price, etc.
  3. 63Compact
    63Compact
    Heres my progressive offy linkage
  4. hamiltonintakes
    hamiltonintakes
    from Chico, CA
    A nice install at Billetproof.
  5. model-a-fan
    model-a-fan
    from Kentucky
    Thanks guys, anymore ref. pic.s?
  6. LabRat
    LabRat
  7. model-a-fan
    model-a-fan
    from Kentucky
    Couldn't take a picture of mine but this is the same set-up I'm running. The issue I'm having is the areas in red are hitting the intake, not allowing the linkage to cycle. Any ideas on how to fix it?
      78.6 KB
  8. model-a-fan
    model-a-fan
    from Kentucky
    P.S. Thanks for the link labrat
  9. dabirdguy
    dabirdguy
  10. LabRat
    LabRat
  11. striper
    striper
    I had a similar issue with the linkage hitting the intake on my Nailhead. I had enough meat on the intake and was able to file some flats onto it for clearance.
    The thing I think you need to do is run the secondary linkage above the throttle shafts instead of below. Then they will push to open instead of pull to open.
    Pete
  12. model-a-fan
    model-a-fan
    from Kentucky
    I'll have to go out and look at it some more.
  13. strombergs97
    strombergs97
    Three things..1. grind the dimples off..2. risers(1").. 3. make a tight linkage setup..
    Duane..
