Transmission
Discussion in 'The Hokey Ass Message Board' started by buddy graham, Jan 28, 2012.
  1. buddy graham
    buddy graham
    from irving tx.
    What overdrive trans. Would work best in a 47 ford with a 327 engine and a 8.8 rear with 355 gears
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    Are you talking automatic or stick shift?
    Don
  3. mgtstumpy
    mgtstumpy
    If auto, 700R (4L60) or 200R as non electric, later 4L60E is electric and requires a computer. 200R is approx 2" shorter in length than a 700R. As an example my '35 runs 3.5:1 rear with 235.75.15 tyres and turns 2k rpm at 60mph.
  4. TexasT
    TexasT
    from Texas
    As stated, the 700 r4 and the 2004r are good units if your 327 is a chevy engine. The plug in the side of the trans is for locking up a torque converter if you choose to have one. Also, you will need a tv cable and the bracketry to hook it up to the carb. The 700r4 has a 3.06 first gear and a big jump to second while the 2004r is much more evenly spaced. A good core for the 2004r can be found under a Cadillac. You can also get the tv cable, and brackets for a q-jet from the save vehicle. It will have the AA code on the tail tag on the pass side. The pan looks like this.
  5. 3Kidsnotime
    3Kidsnotime
    from Utah
    I would go with the 200R a bit shorter lighter and if I remeber it is a ,65 overdrive
  6. Dayzedandkonfuzed
    Dayzedandkonfuzed
    definitely a 200r or 700r4
  7. desotot
    desotot
    if you are thinking manual trans and you don't need to shift quickly a newprocess is cheap with about 30% overdrive but you will have to change the clutch plate.
