transmission problem #64367467467476
Discussion in 'The Hokey Ass Message Board' started by oldskool55, Jul 26, 2005.
  1. oldskool55
    oldskool55
    from socal
    ok so i think everythings cool with my transmission i drive my truck around all day with no problems then i stop at this red light and it sits for a while the light turns green and i give it gas and it just creeps like i have no first gear then it gets rolling and it jumps real hard like it got neutral dropped then it goes fine. so whats the problem here? how can i fix it? its a ford c4/5 automatic....
  2. jerry
    jerry
    Have you checked the fluid level?
    Can act like that with a low level.
    jerry
  3. oldskool55
    oldskool55
    from socal
    its full... would it do this if it was overfilled?
  4. oldskool55
    oldskool55
    from socal
  5. Crosley
    Crosley
    from Aridzona
    the tranny may be dropping out of gear at an idle while hot.
    low fluid , worn sealing rings , hard lip seals , pump gears with too much clearance.
    it would have to be massively over full to foam the tranny fluid... then it would also puke fluid out the vent onto the ground
  6. dragrcr50
    dragrcr50
    sounds like the govenor is hanging up, it is positioned around the tail shaft, and if it is a c4 or c5 you can at about 40 mph simply put it in park for a couple of secondds and it will ratched a bunch and then put back in gear and usually will fre it up but only on a c4 c5. or when it does that pull down to low and then back up to drive before taking off a few times...
  7. oldskool55
    oldskool55
    from socal
    could it be the vaccuum modulator thing?
  8. oldskool55
    oldskool55
    from socal
    when it started doing thid i added some fluid to it and it puked onto my driveway...:rolleyes:
  9. squirrel
  10. The Shocker
    The Shocker
    Sounds like a pressure problem to me.May be a restricted filter or worse a worn pump.I would pull the pan and change the filter first,especially if it hasnt been changed recently.Does the fluid smell burnt or is it dark?
  11. oldskool55
    oldskool55
    from socal
    tell me about it i never want to see this thing again
  12. oldskool55
    oldskool55
    from socal
    filter and fluid are fresh i just got it all together and running....
    im begining to think i shouldve just left it alone and lived with not having reverse:rolleyes:
