Okay, so I went on the website for Muncie Transmission identification but im still confused. I would like to know the date code and what it is? I would like to also know if there is a speedo cable that will work from a 1936 Ford speedometer to this transmission? thank you guys... Main case: 3925661 CT3 46534 Tail case: GM 3846429 Imput shaft base: GM 16 3915020 Imput shaft 10 spline Tail shaft 27 spline THANKS
http://www.5speeds.com/muncie2.htm Casting: 3925661 Years: 1970 - 1974 Ratios: M20 2.52 1st , M21 2.20 1st, M22 2.20 1st Reading Serial and VIN Numbers Serial numbers for Muncie 4 speeds always begin with the letter "P". P stands for Muncie Plant. Not for passenger car as some self proclaimed specialists may think. The letter M was used to ID the Muncie plant for the Muncie 3 speed, so P was the next logical letter. The letter O would add confusion since it resembles zero. The serial number is a date code the transmission was built for a particular year. Serial numbers from 1963 to 1966 included only the month and day. P0101 would indicate January 1st. From 1967 to 1968 the serial number got a year designator and a letter designator for the month such as P8A01, meaning January 1st 1968. One important point is that if you have a Muncie dated with a December build date it was actually built the prior year. An example would be the date code P8T13. This is for a 1968 production car. The T stands for December and 13 is the day. To confirm this simply look at the VIN number. It will usually begin with a 18S101350 or a 28N12950. This means the Muncie was assembled December 13, 1967 for the 1968 model year. The VIN number will usually be a low number. 1969 to 1974 Muncies got a ratio designator at the end of the serial number. An example would be P4D23B. This equates to April 23, 1974, M21 ratio.
