For the transmission gurus and others who have played with the C4 trans... I've been having issues finding neutral, so I remove the shift linkage (using a Lokar shifter) and ran the transmission through the gear manually from under the car to see I for some reason I had the linkage off and the detents were not being hit. That did not show anything, so I proped up the rear end on my '63 Falcon and tryed rotating the drive shaft in all of the gears. Park - no rotation of the gears: Check Reverse - CC rotation (when viewed from under the car looking at the transmission) That didn't seem right Neutral - same rotation Drive - same rotation Is this a simple fix or major?! Could it be the reverse bands or is it simplely a neutral linkage problem...is it some thing else??? Background...transmission is used and never been run on this vehicle. Reviewed the inside when I bought it for any signs of damage or issues, but not a transmission expert. Please help...my maiden voyage has been a long time coming and this is pissing me off. B-Frz
See my post in this thread...maybe it will help? http://www.jalopyjournal.com/forum/showthread.php?t=26310
