Transmission gear help
Discussion in 'The Hokey Ass Message Board' started by cm30, Mar 6, 2011.
  1. cm30
    cm30
    I have an option of running a super-T 10 with a 342 1st gear or the same transmission with a 242 1st gear. What would be a better option behind a 401 nailhead with a 411 rear gear and 750/16 tires? Would I have much of a 1st gear with the 342? Any thoughts?
    cm30
  2. iamspencer
    iamspencer
  3. Da Tinman
    Da Tinman
    I'm fairly sure that 3.42 first with a 4.11 will be a granny low.
    My ot mustang had 4.10 rear and a 3.35 first, first gear was good for 2-3 feet before you had to shift.
  4. 53mercury
    53mercury
    How heavy is your car and how do you intend to run it? Chances are you will be happier with the 2:42 unless it's a dump truck, or you want to roast the tires at will. :) Mike
  5. iamspencer
    iamspencer
    oh yea and put 1:1 as tranfercase ratio
  6. cm30
    cm30
    It will be in a A roadster, a light car. I would rather have more pep then it being a dog. It is a hotrod so I want to have fun with it!
  7. Da Tinman
    Da Tinman
    nailheads are torque motors, so you'll want a tall gear.
    I'm betting that the 4.11 rear gear will actually make it slower than if it had a higher rear gear.
    the 2.42 is what your wanting.
