Hot Rods Transmission for Desoto 276 Hemi?
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Oct 3, 2020.
  1. flynbrian48
    flynbrian48
    I'm busy ordering and collecting bits for my '29 Model A roadster, and have been looking for a modern transmission. The engine (from our '52 DeSoto wagon project) has it's original Fluid Drive and "GyroMatic" 4 speed, (which is available if anyone has a boat and needs an anchor). I'll use a HotHeads adaptor for whatever I choose, I don't want to row a 4 speed, I'm 65 and I've had plenty of cars with manual transmissions. I'm leaning towards a 700R4, for the deep low gear and overdrive, but was happy with the 350TH I had behind the 283 in my last roadster, a '34.
    Anyone have any input on what transmission would make this little engine happy? I've got a Ford 9" with mid 3's gears, should be a fairly light car. 86192607_10222298007821723_2339488279772004352_n.jpg
  2. Dee Simmons
    Dee Simmons
    Morning, I run a great little 276 DESOTO in my 32 coupe and use a 350 trans. Runs great and lots of fun. Highly suggest you check it out. IMG_3222.JPG IMG_3222.JPG
  3. flynbrian48
    flynbrian48
    Thanks Dee. Like I mentioned, I was happy with the TH350 in my '34, but I felt like it should shift one more time. I'm leaving the DeSoto engine alone, right down to the rebuilt 2 bbl, I thought it might be nice to have OD, that it might be a little more bottom end, lower RPM friendly than the rumpity-rump 283. The next thing is finding a decent trans, they're not as common as I'd hoped. Either one. Lot's of 4L60's out there.
  4. Bert Kollar
    Bert Kollar
    I have a 727 Torqueflite that would work I used 2 in my last builds and they are bullet proof and in Ohio
  5. AHotRod
    AHotRod
    How tall of rear tire are you going to use Brian?
    I'd use a T350 trans personally......
  6. flynbrian48
    flynbrian48
    Probably 23575R15's, which are pretty tall. It's cold and rainy or I'd go out and measure them...;)
  7. flynbrian48
    flynbrian48
    Aren't they pretty long compared to the T350?
  8. oldsman41
    oldsman41
    200r4 is almost the same length as a th 350 and overdrive
    flynbrian48 and David Gersic like this.
  9. flynbrian48
    flynbrian48
    I thought they were similar. That'd be good, it'd be nice not to have a huge trans hump.
  10. I'm using a short tail TH350 behind the 330 Desoto in my 40/41 pick up. HHH adapter. Fingers crossed.
  11. Bandit Billy
    Bandit Billy
    Hey FB! BB here. I mounted an A518 Dodge 4 speed (non lock up) 46RH auto behind the 330 Desoto. Hot Heads adapter, gear reduction starter, mini comp shift computer that handles up and down shifting, 4th gear, kick down and electric speedo/cruise connections. Had to do a little frame mod as it is basically a longer 727 but it fit without too much difficulty. I used 3:70 rear posi gears so the 4 speed will make it a bit more drivable at freeway speeds.
    flynbrian48 likes this.
