Running a TH350 in my Dodge Truck project. For my initial startup and engine break-in, can I just block off the cooling line ports in the trans? I won't be driving the truck...just running it for the required amount of time and RPMs. Will this cause a load on the trans at all that would require cooling lines? Before I put the front end back in, I'll have to remove the radiator, so I don't want to have to fill up the lines and connect them to the radiator only to have to remove them. Hoping I can just put fluid in the trans and block off the cooling ports till it's road worthy.
Junk yard,,,,ford crown vicks used to be police cars have a nice heavy duty factory trans cooler in them,,,I run one in my 51 with no problems and no cooler in the radiator...
