Transmission compatability question?
Discussion in 'The Hokey Ass Message Board' started by 8Flatliner6, Mar 19, 2009.
  1. 8Flatliner6
    8Flatliner6
    I'm planning to keep the stock 235 inline 6 in my '53 Bel Air, but I want to reduce weight by replacing my stock cast iron Powerglide automatic with a later aluminum Powerglide. The aluminum version was built for the later series of Chevy Sixes however (194-230-250-292), will the aluminum tranny bolt on my 235?
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
  3. hotrod-Linkin
    hotrod-Linkin
    you are sol on that idea....unless you can get an adapter from speedway.
  4. 8Flatliner6
    8Flatliner6
    do you have a link?
  5. 8Flatliner6
    8Flatliner6
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Won't bolt to the engine without an adapter, and also requires a newer open rear end and driveshaft. If you're going to go to that much trouble, treat yourself to something better than a two speed automatic.
  7. What he said !! Use a 350 Turbo or better yet a 200/700 R4 . With that engine you need all the gears you can get .
  8. d2_willys
    d2_willys
    from Kansas
    Save yourself all the problems and put a 250 or 292 newer 6 and what Bob the Ferret suggested. By doing the engine swap you can have a nice way of putting a manual transmission in there too. Big issue is the open driveline, but fortunately you have leaf springs so it shouldn't be a big issue ala Buick torque tubes.
    If you still want to try an adapter try Wilcap or Bendtsens sites below.
    www.wilcap.com
    www.transmissionadapters.com
    Best o' luck!
  9. 53sled
    53sled
    from KCMO
