Trans Swap
Discussion in 'The Hokey Ass Message Board' started by PorkChopTex, Mar 28, 2013.
  1. PorkChopTex
    PorkChopTex
    from Hurst, TX
    I'm swapping a ST400 for a TH400. Everything I've read says they're the same exact trans except for the switch pitch feature and the bell housing. I'm having a hard time finding one the same length at 28" long from bell housing to the tip of the tail shaft. Anyone know the specs on these things? Also if I do end up having to go with a longer trans what's the going rate for a driveshaft chop and balance and is there a cheap reliable shop in the Fort Worth area? Thanks
  2. pitman
    pitman
    There are some dimension tables that people have posted on the site. See what Search finds.
  3. PorkChopTex
    PorkChopTex
    from Hurst, TX
    Thanks
