Traditional EFI......
Discussion in 'The Hokey Ass Message Board' started by Eddie's chop shop, Nov 18, 2010.
  1. Vergil
    Vergil
    Beautiful work Eddie or Eddie's Chop Shop if you aren't Eddie. We need a name to go with the Eddie's Chop Shop.
    Vergil
  2. terryr
    terryr
    from earth
    Chrysler did offer EFI in 1957? or abouts. It malfunctioned and they retrofitted a carb. The rights to the EFI were sold to this company called Bosch.
    EFI- invented in the USA but sold.
    Transistor-invented in the USA but sold cheap to Japan.
    Integrated Circuits-invented in the USA but sold for a bit more to Japan.
  3. Eddie's chop shop
    Eddie's chop shop
  4. Eddie's chop shop
    Eddie's chop shop
    Just about anything can be converted. The problem with the early Rochester unit is where to hide the injectors. If placed in the original locations they would be a little obvious although hard lines without fuel rails could help with this. I have never had my hands on one of these off the car to really check one out for alternatives but I am sure something can be figured out.
    Its hard to give a cost on something like this unless I have it in my hands to formulate a plan. If you are serious I will see if anyone I know has one I can really stare at and think about.
    Eddie
  5. Eddie's chop shop
    Eddie's chop shop
    and I apologize Gary its not dragging its just next in line!!!
  6. Eddie's chop shop
    Eddie's chop shop
    I am digging the deuces on the hemi, nice valley plates to cover the injectors.!
  7. Eddie's chop shop
    Eddie's chop shop
    Its Eddie, that would be me!
  8. Eddie's chop shop
    Eddie's chop shop
    Here are some pics of a manifold I just started for my mid engine 37 Ford. The car is going to be traditional bonneville outside but serious performance underneath.
    Motor is a twin turbo LSX tall deck block with GM Performance LSX DR heads. I am making the manifold to run two injectors per cylinder, integrated air/water intercooler with 2 90mm throttle bodies being fed from two air to air intercoolers located on either side of the motor just behind the quarter panels. Ford GT transaxle. Current estimates/goals power output of 2000+ hp.
    This last pic shows the various stages of milling the air horns going inside the plenum. Alot of work for something that won't be seen. But for this type of power output manifold flow will be critical.
  9. Novadude55
    Novadude55
    from CA
    Very IMpressive,,
    If I win the lotto I'll give you a call,,
  10. Eddie's chop shop
    Eddie's chop shop
    Been awhile since I checked in I guess
  11. Eddie's chop shop
    Eddie's chop shop
