Technical Towing capacity AGAIN
Discussion in 'The Hokey Ass Message Board' started by carpunker, Jun 22, 2020.
  1. squirrel
    well, this thread got pretty far away from the original question, eh?
    X-cpe, carpunker, 31hotrodguy and 3 others like this.
  2. Boneyard51
    Boneyard51
    Thanks the previous owner pulled all over the US drag racing, with this trailer, with no problems. I just bought the motorhome , the bought a smaller trailer. So I should be good! 3FD14249-14F7-4F39-8894-317A0CCA88E6.jpeg
    rod1 likes this.
  3. anthony myrick
    anthony myrick
    did you forget where we are?
  4. VANDENPLAS
    VANDENPLAS
  5. I’ve read multiple times that drum brakes and single circuit master cylinders are sure to result in a fiery death...wonder how long I have left....
  6. squirrel
    I've been killed by them 8 times already....
  7. 51504bat
    51504bat
    When I was in the Army stationed above Reno I had a '63 4x4 1/2 ton carryall with a 327 and a 3 on the tree. I bought a '56 Chevy wagon for a buddy and towed it to SoCal down 395. Going down the Sherman grade coming into Bishop the brakes got pretty soft but it was 2am so no traffic. When I got on the flat the brakes seemed OK so like a dumb 22 year old I keep going . Dropped the car off at around 6am and went to my parents to hit the sack. When I got up I decided to check the master cylinder. Bone dry. Must have boiled all the fluid out on the way down the grade. Dodged a bullet on that one. From then on I was pretty anal about brakes. Other stuff not so much. It's a wonder I survived to old age.
  8. carpunker
    carpunker
    “ vans wagons trucks”
    31hotrodguy likes this.
  9. carpunker
    carpunker
  10. carpunker
    carpunker
    Why??
    Plenty of smaller than typical old u.s vehicles are rated for that. I just don’t want one for
    This project idea
  11. carpunker
    carpunker
    There are lists I’ve seen them but I can’t find much for this era.
    I also did the google thing which never came up with much except more typical bar talk
  12. carpunker
    carpunker
    agreed and all my main towing trucks are the other fuel newer and manuals
  13. carpunker
    carpunker
    55mph yes exactly I’m fine with that
  14. carpunker
    carpunker
    agreed 3/4 or 1ton or burb type vehicle was allways the plan not a 1/2 ton.
    Just wanted to know which I can choose that have data to back it up
  15. squirrel
    Probably back to around 1970.
    You could use that data to extrapolate...but without knowing what you want the data for explicitly (your own curiosity? your insurance company? the trailer manufacturer? your lawyer? or judge?) we can only guess whether that will satisfy you.
  16. carpunker
    carpunker
    I haven’t seen them either . Well not much anyway.
    And yes GVWR isnt the question
    And upgrades allthough useful won’t help Much in court
  17. carpunker
    carpunker
    Im happy to break hamb “rules” regarding brakes
  18. carpunker
    carpunker
    I vaguely remember seeing something on a Stovebolt forum years ago too but I was hoping for other brands to also compare
  19. carpunk
    carpunk
    Well I had a quick look at that heritage gm site even went up to 1980 and still no trailor cap mentioned (that I noticed anyway.) I know there’s laws around it so how can you prove that your within the law?
    Plus those “ heavy half” versions
    Slightly o.t but..
    I see car haulers made from old 1 ton dually frames
    And pick ups extended with a beavertail which although can move it easy enough ( moving and being able is NOT in question )
    legally they must be useless!
    and that’s with the easily found gvwr . good luck arguing that on the side the road or after a wreck
  20. VANDENPLAS
    VANDENPLAS
    If your concerned about legality and having documentation.
    try contacting an engineering firm.
    we use them all the time at work for exactly this.
    Added weight to a forklift counter weight
    Attachments and/or any modification from factory
    Adding booms and cranes
    Longer forks etc.
    bring in the engineeering company they sign off put a tag on the unit stating it’s all good and we are legal and. Safe to carry on.
    If any other modifications are required they let you know what needs to be done and how etc.
    Takes the guess work out of this stuff and keeps everything safe and legal for everyone involved.
  21. Joe H
    Joe H
  22. squirrel
    The engineering firm needs numbers to start with, there are no initial numbers on the older vehicles...that's his problem.
    I guess if you want to have numbers so you can be sure you're legal, then you need to stick with modern tow vehicles.
    I've never been hassled with old stuff. I've also never had an incident that would bring the legality of my rig into question. Perhaps a careful reading of state laws, where you plan to travel, could put your mind at ease that what you plan to do is legal. If there is no stated load limit, then you can't possibly exceed it, can you? but if the limit is stated in the owner's manual, or a tag on the car, then you can exceed it.
    You don't need an old car forum, you need a legal forum.
    VANDENPLAS and chryslerfan55 like this.
  23. I can tell you that in my case it is a 1959 Cadillac limousine (5,900 lbs) on a 20 foot car trailer with dual axles (2, 250 lbs). Thank goodness there is electric brakes on BOTH axles. Pulling with one ton dually car hauler bed (usually with 50s GM on it too). Makes that 454 earn its keep.
    1 more car I promise, Rex Winter
    Dry n windy Lubbock TX
  24. carpunker
    carpunker
    Oh well another dead end.
    I tried.
  25. VANDENPLAS
    VANDENPLAS
    you are correct squirrel.
    At my job we have modified and built custom attachments for forklifts and wheel loaders.
    Clamps, booms, screens etc.
    called in the engineering company that specializes in this type of thing.
    The measure, calculate, question and go back and forth a few times until they get what they need.
    Tell us what and how to build it
    Once it’s done they indie t and attach there tags to it.
    Not cheap but required so no one gets sued for being stupid.
  26. Hnstray
    Hnstray
    from Quincy, IL
    @carpunker
    I guess I really don’t see the problem. Pick a vehicle that has both a very stout chassis and a body style and appearance you can live with, and make whatever changes and modifications to the axle and suspension, springs, tires, wheels etc. that it takes to carry the loads you have in mind. Add enough horsepower and transmission capacity and you’re on your way.
    If the body you most want didn’t come with a stout chassis, put one under it. Lots to choose from.
    As I see it, it’s very little different than building any other hot rod from a wheezer to what ever level of performance you want/need.
    Ray
    VANDENPLAS and X-cpe like this.
