Technical Torque specs 8BA - with aluminum heads
Discussion in 'Traditional Hot Rods' started by cederholm, Sep 28, 2019.
  1. cederholm
    cederholm
    I'm finding the torque specs for steel heads, but not aluminum for my 1952 Ford flathead.
    Can someone tell me the specs please? Offenhauser heads, composite gasket.
    thanks,
    Carl
  2. prpmmp
    prpmmp
    I have Weiand Heads and copper gaskets, I torque 40 LBS. My torque sequence is to start at one end and go up and down all the way across at 10lb increments. Then re torque after cool down 2 times. Pete
  3. drtrcrV-8
    drtrcrV-8
    I believe that MOST sources recommend start the torque pattern in the center of the head and move out in a circular pattern(as per MOTORS MANUAL, CHILTONS, etc!!)
    town sedan and Truck64 like this.
  4. Ebbsspeed
    Ebbsspeed
    This is what I've always done. Start in the center and circle out to the ends.
    town sedan likes this.
  5. 19Fordy
    19Fordy
