I just checked the manual and it doesnt seem to state a sequence to torqueing the head other than a little at a time with final torque at 95. I'm using a felpro composite gasket. The parts guy said that the gasket only needed to be torqued once but I know most engines have a step process. Thanks for any input, I'm hoping to fire her back up sometime today after all the engine work ive been doing.
don't know what year you're workign on, give this a try? http://www.selectric.org/manuals/57chevytruck/
here you go: http://chevy.oldcarmanualproject.com/shop/1949_53/06engine/6_017.HTM Use the second diagram. The first is for a 216
Its a 54 235. I followed that diagram. I was just wondering if I needed to loosen them and then re torque before I fired it up. I torqued them down last night.
Not to hijack this, but my understanding was that when torquing head bolts, you got there in steps, say 45-75-95 (or whatever final value), making sure that the final torquing was with a single pull. Is that just me? Also...I know FelPro head gaskets claim to not need retorquing once the engine has heat cycled...what caused other head gaskets to need that and/or what makes a FelPro gasket different?
