In a word, NO. 7004r's use a lockup converter. It's a totally different converter than TH350 uses. Good luck with your project. ........Jack
yeah, but the 350 "C" is a lockup, otherwise I wouldn't consider it. I just didn't know if the splines were different or if it worked the same way?? I had a later 30 spline converter, put that in last night and it just spun.. I have the 350C converter here so I was going to try it, but I didn't know if it was the same as the 27 spline in the 700..
350 is an old non-metric design, 700 is a metric design, uses a completely different pump. different size splines, hub, etc
