Technical Torque Converter I.D.
Discussion in 'The Hokey Ass Message Board' started by rockable, Sep 30, 2021.
  1. rockable
    rockable
    What kind of torque converter is this? Itt has a drain plug and has 27t spine but it will not fit on a GM 700R4 shaft. It was sold to me as a companion to the transmission, but it is not.
    Deuces likes this.
  2. squirrel
    The plug was added by someone who drilled a hole into the converter to drain and flush it.
    It's not a lock up converter, so it can't be for a 700. you can tell because the face is not "square" around the outer edge, since there's no lockup clutch in there.
    The rectangular lugs were used on the TH 400 converters, as the TH350 converters for Chevys had tabs, and those for Buicks had small square lugs.
    So it's probably a B3, if you're looking in a Dacco catalog. Fits most GMs with TH400 from 1965-1990, but not the trucks or vettes with the 6 lug converter.
    https://www.buffaloengine.com/catalog/p-100913/gm3-b3-th350-th400-th475-torque-converter
    VANDENPLAS, Deuces and rockable like this.
  3. rockable
    rockable
    Thanks, Jim! Hopefully, we ordered the correct one today.
