Technical Torque converter flush?
Discussion in 'Traditional Hot Rods' started by AGELE55, Nov 16, 2021.
  1. AGELE55
    AGELE55
    I picked up a 700r4 for cheap. Fluid is somewhere between red and brown. I plan to degrease it , drain and refill, and see how she runs.
    Any way to flush the removed TC while its out? No sense putting in a new one in a questionable tranny.
  2. TA DAD
    TA DAD
    from NC
    I have always just put them in the parts tub after draining it as good as you can and sticking the hose in it and letting it flush out with varsol.
  3. Marty Vanin
    Marty Vanin
    Just turn it upside down and let it drain for a few hours.Remember that converter has a clutch lining inside and pumping varsol into it may deteriorate the lining. Okay to do that on non lockup converters.
    AGELE55 likes this.
  4. Elcohaulic
    Elcohaulic
    I was taught to never use solvents on automatic transmissions and rear end gears.. Flush them with the oil that they run on..
    46international and AGELE55 like this.
  5. squirrel
    you can drain it, then add a quart of ATF, slosh it around, and drain again. And repeat until you get tired of it. Don't expect much improvement.
  6. MeanGene427
    MeanGene427
    from Napa
    Yep, I would never use solvent- just let it drain overnight. And wish you had a Ford converter equipped with a drain plug lol
  7. sunbeam
    sunbeam
    This has worked for me . Lay the converter flywheel side down stick a hose as far down as you can then use an air blow gun with a shop rag wraped around it so it will seal the converter and pressure the converter so the oil will flow out the hose
  8. oldsman41
    oldsman41
    I just let them drain out for a day and put fresh atf in a quart is fine slouch and drain for a day fill and get busy
  9. jaracer
    jaracer
    When I taught automatic transmission repair many years ago, I bought a machine to flush torque convertors. It pumped solvent in the middle while slowly turning the convertor. About every 15 or 20 seconds it delivered a blast of air with the solvent. If the convertor didn't have a drain plug, the company that built the machine supplied 1/8 in pop rivets with a sealed end. You drilled an 1/8 in hole in the outer diameter staying in the pump region of the convertor. That way you could drain all the fluid before putting it on the machine. Since the machine had a lid, you just left the hole open while cleaning. After you let all the solvent drain, you installed the pop rivet with a little sealer. It worked very well.
  10. TA DAD
    TA DAD
    from NC
    Well imagine that ! using solvent to flush a converter out.
  11. squirrel
    were those lockup converters he was flushing with solvent?
  12. Our converter flushing machine uses atf and air to flush them
    Desoto291Hemi and VANDENPLAS like this.
  13. I have been told to drill a 3/16" hole, tap it 1/4-20, and put a set screw in it with sealant on the threads. Never had the nutsack to try it.
  14. RmK57
    RmK57
    I wouldn't want my converter to be number 47 on the flushing list if your using the same oil. Even if it was filtered.
  15. I honestly don’t know how often it gets changed. We are a little different then a production shop.
  16. Kevin Ardinger
    Kevin Ardinger
    Can’t do that on a lockup converter. You will drill into the clutch.
  17. I don't ever use that new fancy stuff.
    Kevin Ardinger likes this.
  18. Marty Vanin
    Marty Vanin
    But , for the guys that do use the new fancy stuff,Kevin is right.Leave the drill in your tool box.
  19. jaracer
    jaracer
    That was just before lockup convertors came out.
  20. jaracer
    jaracer
    Not if you drill in the pump area of the convertor. The clutch material is in the turbine area.
    Randall, loudbang and Mark Yac like this.
  21. Yes...then use a 1/8th pipe tap with some grease on the tap to catch the metal. If you can pressurize just it a bit at the hub, all the better. Use an allen head brass plug and it should seal on its own.
  22. Simple solution. Spend $100 buy a new convertor. Problem solved
    Budget36 likes this.
  23. Elcohaulic
    Elcohaulic
    I like the 1957 to 64, four speed, Super Hydra-Matic. It had a drain plug on the coupling..
