Hi. I need to find some scematics on what goes where in there. I opened it to change a sealing, and out fell a bearing, a shim and some other stuff. I have tryed to google it but i found nothing. Grateful for any help.
The bearing goes in first followed by the thrust washer and then the speedo gear. Here is an illustration from Mac Van Pelts website that should help. Everything should be held in with a snap ring. Good luck. http://www.vanpeltsales.com/FH_web/FH_images/FH_rearend-pics/Flathead_Rear_Axle_Assy_1938to48.jpg
