Top Link Brackets
Discussion in 'The Hokey Ass Message Board' started by Jmountainjr, Feb 27, 2012.
  1. Jmountainjr
    Jmountainjr
    While putting together a traingulated four link for my roadster, the common upper tabs for the rear axle housing connection were not working out. I wanted something a bit stronger and easier to keep lined up during welding. After many thoughts, I came up with this two piece bracket. The top part is .188 wall 2X2 square tubing and the lower part is a piece of.188 wall 3X3 sliced. It did require fabricating the four .180 thick washers to properly space the bushings in the brackets. Not welded in yet, but I see no down side. Comments?
  2. brandon
    brandon
    Solves a few issues....saw a housing for a fox body that actually had the housing cut for uppers....your going to box the ends?
  3. HotRod33
    HotRod33
    from MO
    I think they should work fine......
  4. racemad55
    racemad55
    Neat idea, very clean.
