tool question.... how come no one makes this?
Discussion in 'The Hokey Ass Message Board' started by evobuilder, Mar 18, 2013.
  1. evobuilder
    evobuilder
    how come, after all these years, no one makes a tool to shorten bolts? We all have a ton of bolts that are too long, and we need them shorter.... but the only answer is a vice and a cutoff wheel. Seems like someone could make a small cut off wheel and a jig/clamp so you can cut that 1/4 20 cap head screw from 1.5" to 3/4" without having to break out the cutoff wheel.
    Just sayin!
  2. Diavolo
    Diavolo
    Because who would pay $500 for a tool when they have a hacksaw and a die?
  3. We've got a two-piece tool that works just fine: a small vise and a band saw.
  4. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    I have plenty of bolts that get cut that way. The tool I'd rather have is a stretcher! Or sometimes a fattener/slimmer. Like that can take a bolt and make it into a 3/8 instead of a half or vice versa...
  5. Don's Hot Rods
    Don's Hot Rods
    from florida
    Yep, I always run a regular nut up on the bolt, cut off the excess with a hacksaw, clean up the end on a grinding wheel, and then remove the nut so it cleans up the threads. All of a 5 minute operation.
    Don
  6. I must agree with Don, I've had the multi tool for years, Grinders are God my friend,
  7. evobuilder
    evobuilder
    I must agree.... I would not pay 500 bucks for a tool that does this, but hey, if someone invented a slick tool to cut, shorten and stretch bolts and screws.... I am sure Harbor Freight would knock it off (sub par) and sell for 29.99 and if you have a coupon, it would be 6 bucks. Ohhh... dare to dream :)
    Still seemed like a question worth asking.
  8. Rickybop
    Rickybop
    from Michigan
  9. They dont build tools that people wont buy......
  10. Hack saw or band saw works for me. HRP
  11. blowby
    blowby
    from Nicasio Ca
  12. tommy
    tommy
    I'm a tool freak but lets not get crazy.
  13. manyolcars
    manyolcars
    Funny! The first power tool I ever had was a drill but the grinder was second
  14. 296 V8
    296 V8
    from Nor~Cal
    It has crossed my mind to make a little holding dealy to use in the chop saw
  15. FANTASY FACTORY
    FANTASY FACTORY
    Why aren't you buying the right size bolt from the get go?
  16. Carter
    Carter
    I'll post a picture of my combination wire stripper/machine screw cutter because I'm at work, but I have a large scale version of these at home made for cutting bolts, up to 3/8" if I remember correctly.
    Sent from my DROID device using the TJJ mobile app
  17. Carter
    Carter
    Found a picture.
  18. propwash
    propwash
    from Las Vegas
    What I've always done - sometimes use a pair of boltcutters (seems logical to me) for expediency and have even run a die up there with the nut to do the best job after grinding and buffing. The actual tool for this process (bolt-shortening) that does the least damage and leaves a clean product is a lathe.
  19. No offense but it sounds like you already have the tool, you can break that one our or a different one. No matter what the tool is called you still have to break it out.
  20. toreadorxlt
    toreadorxlt
    from Nashua, NH
    buy a used lathe for $500. make your own bolts to any length you want.
  21. problem solved. I probably only have to cut one a year. can't see it worth buying.
    I have a nut splitter for rusty or stripped or cross threaded nuts. I needed it for one stinking nut 35 years ago and have only used it once since.
    same goes for my radiator fin combs and my fan balancing tool.
  22. Skeezix
    Skeezix
    from SoCal
    Ding
  23. manyolcars
    manyolcars
    My grandpa gave me his 37 Ford when I was a kid and the nuts and bolts were badly rusted. I lusted after a nut splitter from JC Whitney. 40 years later Horrible Freight had'em for about $6 so I got one. The splitter was softer than the nuts. Of course by now I have better ways to get nuts off but its tough to destroy a childhood dream
  24. mine was $8.00 in 1967 just a cheap USA made tool that will never wear out. not one of those high zoot imported jobs that only work once
    wow that was 46 years ago. time sure flies when you're having fun
  25. big vic
    big vic
    from cary il
    That benchtop chopsaw seems like just what the OP was talking about a little vice with a cutoff wheel built in
  26. saltflats
    saltflats
    from Missouri
    Get you some cuppling nuts and cut them to varring lengths run them down the bolt then wack them off.
  27. blowby
    blowby
    from Nicasio Ca
    Yes, that's pretty good. I have a thin 4" cutoff wheel mounted on a small bench top motor. Does pretty much the same thing, just have to hold the bolt.
    As far as buying the right size to begin with, if you've never been in the midst of a project or repair and needed to add/replace a bolt, didn't have the right size on hand and didn't feel like stopping work to go buy one someplace...
    Also, often you need a 1-3/4" length, for example, and in stock are 1-1/2 and 2"
  28. 1971BB427
    1971BB427
    from Oregon
    I've used my Milwaukie portaband for years to cut bolts, then just touch them up on the bench grinder.
  29. Mr48chev
    For me that's an extra three mile trip to the store and Sundays and eight mile trip to the store.
    I've probably got 500 new small bolts in tubs in the shop but a lot of times I need three or four that are shorter and or longer than what I have. Not having to spend a half hour running after a hand full of bolts would make having something to cut them off worth the cost.
  30. gutpile
    gutpile
    from Texas
    You need to get the electrical crimper pictured above, make sure it has the bolt cutters. These things are cheap hamb'bers. like $6. I had a neighbor come over last weekend looking for a 8/32 bolt for a carb on his lawn mower. I took a bolt out screwed it in the cutter to the proper length squeezed it unscrew it and bam the right lentgh and threads are good and it is cut square. No vise, no hack saw, no cut off wheels, and no cleaning up threads. I could gave him 10 bolts by the time I dug any power tool out.
