tool name and where to find it??
Discussion in 'The Hokey Ass Message Board' started by 41chevytruckinga, Mar 25, 2011.
  1. 41chevytruckinga
    41chevytruckinga
    Can someone tell me the name of the tool I need to romove the bolts on the body of my 41 and 46 chevy trucks and where I can find it? I have found a screwdriver bit that looks right but it is too small. They look like a squared off figure 8/x mix. :confused: any help would be greatly appreciated!
  2. Master of None
    Master of None
    Those are called clutch head screws. Napa carries some sizes and so do most tool company's. Check LMC truck, Paddock and Jim Carter. good luck!
  3. scooterseats
    scooterseats
    from East Texas
    I do not know of a source but this type of drive is called a "Clutch Head". Early Chevy's used this type of fastener a lot.
  4. 41chevytruckinga
    41chevytruckinga
  5. Potax670
    Potax670
    from Utah
    They are called a clutch bit Snap on makes them.
  6. http://www.mcmaster.com/#clutch-head-screwdriver-bits/=bobltt
  7. Potax670
    Potax670
    from Utah
    APEX also makes them.
  8. Cymro
    Cymro
    Note to British rodders, I purchased some from the Snap on Van, not cheap, then a couple of Sundays ago I spotted a Special offer driver and bit set at my local "Aldi" discount supermarket, this kit had all three common sized clutch bits in it all for around £7 or £8 if I remember correctly whether or not the cheap ones will last the pace is another matter but for occasional use? you pay your money and make your choice. (Prior to this I had never seen clutch bits sold in the UK and Mr Snap On had to special order the bits from the US, and they took nearly three months to arrive.)
  9. 1Bad67
    1Bad67
    Harbor Freight has a set of a bunch of bits that has several sizes of clutch heads in it.
  10. Kustom Kid 53
    Kustom Kid 53
    I just got some from my Mac tools guy.
  11. Midwest Rodder
    Midwest Rodder
    I looked at mine when I was taking off the cab of my truck, scratched my head and grabbed the die grinder. I wasn't goint to reuse them or go back to that style bolt so I cut the damn things off.
  12. J scow
    J scow
    from Seattle
    That "square recess" head is technically called a Robertson drive.:D:cool:
    [/QUOTE]
  13. 41chevytruckinga
    41chevytruckinga
    thats probably what i will do to most.
  14. Markgyver
    Markgyver
    I bought a assortment set of bits that have some at Autozone
  15. toolman1967
    toolman1967
    I ran into a bunch of clutch head bolts and screws on mine also, Fortunately I had a box of HF inset bit that worked on the smaller screw sizes and my die grinder fit the larger ones perfectly.
  16. falconsprint63
    falconsprint63
    from Mayberry
    chev's of the 40's has clutch head stuff and I think they have loaners
  17. plym_46
    plym_46
    from central NY
