Technical Too many volts coming from alternator?
Discussion in 'The Hokey Ass Message Board' started by slim tempo, Apr 19, 2020.
  1. slim tempo
    slim tempo
    I am in the process of running wires in my 1964 Chevy Biscayne. I installed a 1 wire alternator and it is putting out 14.3 volts to the battery when the engine is running. I checked the voltage that runs to the ignition switch and it reads 14.3. I checked another lead to the heater and it read 14.3 volts. Is there supposed to be that many volts running through the system? With the 1 wire alternator, I am not going through a voltage regulator.
  2. Jack E/NJ
    Jack E/NJ
    from NJ
    Yes. It's good. Jack E/NJ
  3. greybeard360
    greybeard360
    Sounds like it is working like it should. Those sometimes will run around 14.6 - 14.7.
  4. onetrickpony
    onetrickpony
    from Texas
    14 to 14.5 is good. You are right in the sweet spot.
  5. anthony myrick
    anthony myrick
    12 volts is a generic term.
    Your alt puts out more than 12, your battery stores more than 12
    Lloyd's paint & glass likes this.
  6. theboss20
    theboss20
    Your numbers are good...a one-wire alternator has the regulator built inside the alternator...
    Sent from my iPad using Tapatalk
  7. MAD MIKE
    MAD MIKE
    from 94577
    1 wire alternators are internally regulated, and at that, they don't use the other two 'sense' wires.
    So your alternator is always going to show the higher voltage, it won't change.
    A 12volt system is really a 13-14.4 Volt system
    A 12vilt battery is really 12.4-12.6V battery.
    You can't charge a 12 volt battery with 12 volts, it needs to have a higher voltage to charge and maintain system voltage.
  8. southcross2631
    southcross2631
    Some of the cheap 1 wire alternators have to be revved up the start working.
    Your voltage is right where you need it to be. When it gets over 15.0 it starts to cook the battery.
    I had an O/T 67 Camaro when I lived in Az. The regulator stuck and the volt meter went to 17 volts
    it had really bright headlights but you could smell the battery acid boiling. I had to buy a new regulator and a battery. I was on my way to New Mexico and it was the middle of the night so I had to keep going.
    town sedan likes this.
  9. slim tempo
    slim tempo
    Thanks for your help. I understand it now.
  10. theboss20
    theboss20
    If that ever happens to you turn on every load you can including the blower motor to high...or unplug the regulator until it settles down then plug back in for a while...will get you home.
  11. 41rodderz
    41rodderz
    from Oregon
    We all wish our alternators ran 14.3 volts .:D
