Hey everyone i got a small engine from my 50 Crosley and from the factory it came with pal nuts on the connecting rods and dist nut. Now that it will be getting re assembled i'm not sure weather to get new pal nuts and use them or use loctite without the pal nuts? Just something in my head thinking about sheet metal nuts as a locking nut don't put me at ease haha
ditto loctite. I've never trusted pal nuts on the second or third go-round. always concerned about one getting loose in the engine if the delicate ribs were damaged on the last tightening. WHY BE ORDINARY ?
Do you have the option of using a crimped metal nut instead of the free spinning nut with the palnut? In my line of work (aerospace) we always use some form of mechanical locking because loctite has proven to not always be reliable 100% of the time. That said we don’t use palnuts as our means of mechanical lock, we use crimped metal nuts. Also, I’m not sure blue loctite is compatible long term with oil or oil vapor so you may want to look into how it behaves in an oil environment + heat before it goes into your engine. The last thing you’ll want is that nut backing off.
