Hot Rods To chop or not to chop??? 1941 GMC
Discussion in 'The Hokey Ass Message Board' started by teamr2r, Mar 1, 2013.
  1. teamr2r
    teamr2r
    from TN
    Whats your vote? To chop or not to chop? Its channeled about 4 " and I have never chopped a top yet. I got some great tips from 2 friends: Luke and Ricky Brown. Just need some more feedback and TIPS!
    Please vote and post your tips!
  2. alchemy
    alchemy
    Not much harder to chop than that. You will have angle and pie cuts all over the thing before you're done. Unless your two friends are experienced, I'd pass on this for a first-timer.
  3. Fenders
    Fenders
    All it takes is time, patience, and some thinking....
    What the hell, it's only metal, go for it.
  4. 53fordcustom
    53fordcustom
    Less talk, more chop..
  5. The only way you learn is by doing it. Chop it!
  6. adam401
    adam401
    Needs a chop. Guess your gonna learn. Amongst other things Ive chopped 2 trucks and everybody does them about the same way. Alex Gambino posted a real good thread on chopping a pickup cab. You should look it up. Pictures tell the whole story. Just a tip I always strip the paint off the pillers, doo tops and areas of the roof to be split and arround the back window first, then mask off my cuts. Makes life easy. Cut that fucker up.
  7. I've always thought about doing one of those , but different kind of chop.
    About an inch wedge in the back to 0 at the wind shied, and just tip the posts back.
    Then rework the extra bulbously style roof to a more proportioned curve .
  8. 3R CRUZER
    3R CRUZER
    from Kerman Ca.
    Chop it. If you do chop it, how much of chop are thinking about?
  9. studeynut
    studeynut
    I'd finish building the rest of the truck, then decide. You might like the overall look without the chop. You could then photoshop chop or just take a picture and use scissors to play with the look. I personally love chops but if you do it and don't like it, its very hard to undo.
  10. moparmuscle1
    moparmuscle1
    Sorry , Chop Chop
  11. mustang6147
    mustang6147
    from Kent, Ohio
    I have often thought about choppin mine, but am gonna do a sun visor first. Tough call but I would stay between 2 and 4 inches.
  12. b-bob
    b-bob
    The job would be a lot easier with a second top to stretch it out.
    Would only require one weld across the top instead of two. Good luck.
  13. when in doubt, chop some out.
  14. pinkynoegg
    pinkynoegg
  15. NEWFISHER
    NEWFISHER
    from Oregon
    Everyone needs more of 2 things in life: Chop and cowbell
  16. barrnone50
    barrnone50
    from texas
    My vote would be go to the Photo Shop Crew and let them do the chop chop!!
    Ask them to do what you would like to see.. They would make it happen. There is a lot of talent there and you could see for your self if it works..Man its your ride and you have the vision of what you are trying to make the truck look in the end. To Each their own!! will be looking a subscribed to see how you make out. Remember its your ride and build like you want..:D
  17. XXL__
    XXL__
    Just think it through before you start cutting... and then cut!
  18. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Chop the living shit out of it.
  19. fleet-master
    fleet-master
    when asking such a profound question...the answer is almost always : Chop It ...so what are you waitin fer? Chop it hard
  20. 36couper
    36couper
    from ontario
    Unless you are 5' tall and legs like a 5 year old, don't chop it.
  21. Marcel8u
    Marcel8u
    Chop it.........Chop it........Chop it........and some more chop
  22. 40FordGuy
    40FordGuy
    What XXL said.
    4TTRUK
  23. If it's your first keep it mild. We did one at school. It was more complected than it looked. Are you running bed and fenders?
  24. When in doubt Chop it:cool: and paint it black:cool::cool:
  25. flynbrian48
    flynbrian48
    Yeah, I like that idea, although you might be able to get a little more than in inch off the back. Leaning the posts back looks better, and would make the chop easier for a first time job.
    Brian
  26. Wardog
    Wardog
    I'd build it first and check your seating position, no point chopping it just to give yourself a sore neck. Then if you do chop it at least you have a finished chassis to hold the cab rigid.
    Sent from my DROID device using the TJJ mobile app
  27. What makes this chop a bit more difficult,is that when the top is cut and the amount removed from posts,you end up with the top [of windshield opening] being =WIDER=than the body below it....
    this is hardly never the case on a chop.
    Add to that the fact it is heavily reinforced around that windshield opening as well.
    THEN......All the inner "tin" needs cut to match and has all "clutch drive" screws holding it in place.....
    the windshield frame ,is of course the channel style which does not like to be bent much.....I've done these up to 6" and that is about all I wanted....its a little tough.
    study it all out well and thouroughly and do all the
    'figuring" before you cut.
